ive tried 2 different pulley pullers. one was for Chrysler only from auto zone. nothing. the other pulley grabs from the outside and same thing nothing but a bent pulley. car is from up north and I see a tad bit of rust on the spacing between the pulley and the crank snout. I notice my pulley says made in china so I assume that's not original. it looks like someone used an impact to tighten the pulley bolt down.
what can I do to remove this pulley. I don't want to go any further with out advice. all I was trying to do was a timing belt swap |
I can tell you from experience that pulling on the outside of the pulley will do nothing. When I finally got the right puller that grabs the inside it took a half inch drive impact wrench working at full potential to convince that pulley to come off. The tool was at its breaking point.
The correct puller is a must. You might try spraying it with something like SOK or PB Blaster.
A little heat goes a long way.. Put pulling pressure on pulley and then add a little heat. Make sure your pushing on the inside of the crank and pulling from the holes in the harmonic balancer with the hook part toward the center or crank shaft. To replace shine up the crank with fine emery paper, remove any burs, same with your harmonic balancer.
Addicted to Mopar You can tell how old I am.. 65 Dodge Coronet 6 cyl 2dr Post 66 Ply Satellite with 273 engine swap to 69 340 4spd 70 340 4spd Dart Swinger "Those were the days my friend" 73 Charger SE Had a few Vetts on the way 69, 85 Several Neons some flips 01 Sebring flip Cruiser's 01, 220K Gone to a new home Cruiser 03 133K Gone to a new home Cruiser 06 110K Project Gone to new Home Cruiser 05 Ltd 120,809 bought with broken belt Oct2015 May 16 Resurrected to once again roam the streets. 20 Miles South Of Pittsburgh Last edited by JoeX; 18 Apr 2017 at 12:10 pm. |
ive tried both the outer and inner pulley puller. I believe the inner pulley puller is the right one.
I think someone had the same problem as me with this car as the timing cover looks melted behind the pulley. just noticed that im going to go get some pb blaster ive sand crank once I get my emery cloth. ill need to buy a new pulley after this il see if I have a propane torch and try that route never in my life have I had a problem like this |
I never push against the loosened crankshaft bolt to avoid any chance of damaging the threads. The small black puller requires a pin about 1/4 inch dia to push against and another a little longer to remove the pulley all the way.
Addicted to Mopar You can tell how old I am.. 65 Dodge Coronet 6 cyl 2dr Post 66 Ply Satellite with 273 engine swap to 69 340 4spd 70 340 4spd Dart Swinger "Those were the days my friend" 73 Charger SE Had a few Vetts on the way 69, 85 Several Neons some flips 01 Sebring flip Cruiser's 01, 220K Gone to a new home Cruiser 03 133K Gone to a new home Cruiser 06 110K Project Gone to new Home Cruiser 05 Ltd 120,809 bought with broken belt Oct2015 May 16 Resurrected to once again roam the streets. 20 Miles South Of Pittsburgh |
The one that Autozone and OReilley loan out is the OEMTools 27139 and the longer rod shown in the picture is too short to fully pull out the balancer.
Be careful and test fit the rod in the bolt. The first one I got from Autozone was a very tight fit and got stuck in the bolt when I used it. They refunded me the loaner cost anyway. I then went to OReilley's and they gave me the same kit. That's when I had to resort to using the crankshaft bolt to get the last part of the balancer off the shaft. |
Same tool I used, but I made a longer push rod...
Think impact wrench.
Using an impact wrench makes this much easier. I've always found that the hammering motion of an impact wrench will often allow a puller to move a pulley when the direct torque of a hand wrench can break the puller. Here's my rig to break the pulley loose. ![]()
Thread Tools | |
Display Modes | |
How to remove Harmonic Balancer? | TeddoNawthCaroliney | Tech & Performance Forum | 17 | 04 Mar 2017 10:47 pm |
harmonic balancer help | roadmap | Tech & Performance Forum | 9 | 24 Mar 2016 11:53 am |
Harmonic balancer | Jel3 | Tech & Performance Forum | 11 | 23 Sep 2015 06:10 pm |
harmonic balancer | Jassy | General PT Cruiser Discussions | 2 | 01 Jan 2012 12:26 pm |
harmonic balancer | mdskinner731 | Tech & Performance Forum | 10 | 15 Sep 2011 09:04 am |
