Should I buy? 2007 52K miles
  • 1 Post By Chucky
Old 21 Apr 2017, 10:46 pm
Default Should I buy? 2007 52K miles
I had a 2001 for 16 years got 225k miles out of it. I found this 2007 it has 52k miles. The only thing was the air condition needs either replaced or fixed.
they were asking 6000 but said I could get it for 4500.00
I can't really find another car I like, I test drove it and it seemed good.
front bumper is messed up.
Just wanted to get thoughts. Thanks
Old 21 Apr 2017, 11:57 pm
Default Re: Should I buy? 2007 52K miles
Most PT Cruisers around here are going for 2500 or less unless extraordinary in some way. To pay that price for no air and a "messed up" front bumper doesn't fit me at all unless it is in every other way perfect and well accessorized.
I do love that Inferno Red color though.
Old 22 Apr 2017, 12:36 am
rckstein's Avatar
Welcome to the forum
Please go to: Welcome New PT Cruiser Members - PT Cruiser Forum and introduce yourself.
What part of the country is the vehicle located? I used the Kelley Blue Book website to get a quick estimate on the vehicle you're considering. I'm assuming it's a Touring Edition. Private Party in Good condition is $3073, it could be a little more if the a/c worked and no messed up front bumper. Hard to tell what could be wrong with the a/c doesn't seem like it would have enough miles on it for something to be broke, may just be low on charge. Is it at a dealership and they don't want to investigate the a/c issue? If they could fix it cheap enough it could add more to their resale value. What's wrong with the front bumper, can't really tell from the pics other than the gap along the bottom of the grille and the top of the bumper looks much wider than normal. Does it look like they hit something with the front? On the pic of the engine bay, it's missing one of the fasteners that holds on the grille on the passenger side. And it looks like they sprayed the engine with some kind of engine shine product. I hate that because you can't tell what they might be hiding. I prefer a dry but clean engine, so you can see if there are any leaks. And even though it is low mileage, it is a 10 year old vehicle and per the Owner's Manual, the timing belt is recommended to be replaced at 10 years. You can estimate $1000-$1500 to have that work done at a dealership.
For comparison, using KBB to get a value on my PT Private Party in Excellent condition would be $2451. My PT has 143,000 miles but everything works, never been in an accident.
I think they're asking too much, maybe $4500 if it had no issues and the timing belt work had already been done. Per KBB, if it could be graded in Excellent condition and that would be with no issues, Private Party would be $3524.
Old 22 Apr 2017, 07:42 pm
ptprice's Avatar
If your replacing the front bumper cover that could be a couple of hundred. If they could have fixed the A/C cheap it'd a been fixed already! Figure at least $600 to $1000 for a new air conditioner compressor and other necessary A/C work and fixings. The mileage is OK but it's still ten years old. Next'll be the timing belt. Probably won't be mileage but the ten years! The A/C might be why they're dumping it!
I helped a friend looking for a PT Vert a few weeks ago with similar mileage. The dealership brought it to "good ?" condition. Every thing finally worked. It was loaded! My friend passed up buying it even though the deal ended up being around five "G's" out the door at the dealership! I found hidden body damage repair they'd hoped wouldn't be noticed!
HOW TO CHECK FOR A CLUNKER!To check for Bondo take a simple five dollar telescoping magnet, gently pinch the first extension so the magnet, padded with masking tape, (DON'T SCRATCH THE PAINT!) will still hold on a good metal surface and the pinch allows the telescoping function without the magnet coming loose. It should hold all the way out to full extension! Put one or two business cards between the magnet and the good metal surface and pull the telescoping feature out of the pinched portion once again. The card, representing just a bit of Bondo will space the magnet far enough from the surface so it won't hold efficiently. BONDO! BEWARE! You'll have a $5.00 Bondo tester as good as a high dollar paint thickness tester.
Don't be fooled with those shiny tires. Check to see if they're a set, the proper size, how they're worn (wear pattern) and how much they're worn!
Also check for over spray and bad tape marks indicating a repaint or touch up! Check for pulling, wandering, vibrations, brakes, idle exhaust flutter, oil fill hole flutter test and alignment. Peek at all dip sticks, reservoirs, belts, wires and hoses. Try every light, signal and accessory a few times. Put a volt tester on the battery without the PT running. Hope for at least 12.5 to 13V. Start it up and expect for more! Crawl underneath or better yet get it on a rack. At least look for leaks.That you can do.
Finally, always have an independent garage check it out. $30 bucks or so there can save a lot of head aches! NO surprises! this kind of act can really PO a dealership and even private sellers. Once in a while you'll find an honest one but let the buyer beware! That's you!
I'm sure I've missed lot's you should look out for. You've come to the right place to find it as far as PT's go! I'm just an old and forgetful geezer who enjoys his PT!
I'd suggest using the info you get on the Forum and try for a much better price or move on. rckstein's advise very valid.
Happy Ptin', ptprice
SOOO BIG 2005 PT CRUISER, LIMITED EDITION, SIGNATURE SERIES
Cool Vanilla White, 3 Coats. 2.4 DOHC 16V SMPI Eng. Vanity Cover, 4 Spd. Auto Trans. 2.6 Overall Top Gear, Lock-up Torque Converter. PT Chrome Clad 16" X 6" Wheels, P205/55 R16 Cooper Starfire/Solarus tires, Touring Suspension. Chromed Side Spears, Grills, Fuel Filler Door, Door Locks, Handles/guards , PRND3-1 Bezel, Tail Lights, 3/8" Belt Trim, 5 piece bumper trim. Cool Vanilla White shift ball, Leather tilt steering wheel, Cruise Control, Power Mirrors, A/C, Deep Tinted Sun Screen Glass, Power Moon Roof, Fog and Back-Up Lights, Rear Spoiler, Variable Front Wipers W/Washers, Rear Wiper/Washer, Key less Entry. Replacement 2001 Dark Taupe Grey Suede/Leather Trim Seats, Dual Seat Storage Drawers, Drivers Side Power Seat Height Adjust. Full Length Console, Locking Glove Box, Overhead Temperature/Compass Console, Rear Shelf Panel, AM/FM CD GPS Navigation Radio, 6 Premium Speakers. Back up Camera, 7" Monitor.
Old 16 May 2017, 09:24 pm
I bought my 07 last August for 3k with 59k miles. Very clean car. Only thing wrong is air bag light started chiming,and the button for the emergency flasher is missing. There are a few suggestions on what to do with the air bag issues here. The little car now has almost 77k miles now. Runs and drives like a new car. I love these things! Very fun cars🙃
Handy_Cruiser likes this.
2007 Touring Convertible turbo low miles alka2710 Classifieds: For Sale/Trade 0 06 Sep 2015 04:58 pm
2007 PT Cruiser with 30,000 miles danielcrmstr Classifieds: For Sale/Trade 5 19 Apr 2014 07:19 am
2007 Limited Edition 10k Miles MomPTCruiser craigslist 1 07 Jan 2014 06:39 pm
2007 Base 5spd - Chicago - Low miles lakersfan1 Classifieds: For Sale/Trade 4 29 Apr 2012 09:14 pm
2007 Cruiser with 33,719 miles on....already has an oil leak??? xxcutetaraxx General PT Cruiser Discussions 11 26 Mar 2011 08:32 am
