2002 cruiser ignition cylinder replacement
Old 28 Apr 2017, 05:11 pm
Default 2002 cruiser ignition cylinder replacement
Hi all,
Have a 2002 cruiser with the grey key.was advised to try changing ignition cylinder on it due to key not turning all the time. Went to the locksmith and he made me a new cylinder with a new ley. My keys also fit in an turn the cylinder. Looks easy enough to pop the old out. My question is he looked at my key but didnt mention anything about it being a transponder key or needing anything programmed for it. It looks like a normal lock cylinder with nothing on it that would apear to read a transponder key. Can anyone advise how you tell and how do you pop the old out. Thx
Old 28 Apr 2017, 05:36 pm
Default Re: 2002 cruiser ignition cylinder replacement
The transponder key sensor (SKIM) is separate from the cylinder/ lock
If your transponder key works the new cylinder, you are ok.
Trying to change ignition cylinder. 2002 limited edition Thomasant Tech & Performance Forum 0 22 Apr 2016 04:34 pm
Ignition cylinder replacement Whathaveistarted General PT Cruiser Discussions 9 10 Mar 2016 09:53 am
Help with ignition cylinder? mouthfulofbirds Tech & Performance Forum 4 02 Dec 2013 07:18 pm
Bad Ignition Cylinder Tumblers dardack General PT Cruiser Discussions 3 13 Mar 2013 03:53 pm
2002 PT Cruiser horn honks on ignition mikenguy General PT Cruiser Discussions 0 17 Oct 2010 06:25 pm
