Won't start
Like Tree3Likes
Old 30 Apr 2017, 10:34 am
Default Starter????
My 02 PT would not start so we thought it was the battery. bought a new battery but car still will not start but all the lights work. Someone told me it might be my starter. Does that sound right? I was thinking of selling her so maybe that's my sign to move on to a bigger family car
Old 30 Apr 2017, 11:07 am
Default Re: Won't start
yes chances are you may have a bad starter, theyre inexpensive, LABOR ONE hour two at most
Old 30 Apr 2017, 12:01 pm
A starter will run you about $100 for a remanufactured one. Before changing out the starter check the connections. Does it turn at all? if not it may be in the ignition switch. If you remove the starter auto parts places will check them for free.
2002 Limited Edition 2.4 Auto with 177k Miles
Old 30 Apr 2017, 01:04 pm
If you tap on the starter while having someone turn the key it may start, if its the starter. If it starts you'll know what to change.
Use a piece of wood to tap on the metal part on the end of the starter, not the plastic.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 30 Apr 2017, 01:34 pm
thank you. i'll try that 👍
Old 30 Apr 2017, 01:39 pm
I would suggest taking a volt meter and post what the battery voltage goes down to when you are trying to start it.
Also check to see if you have voltage going to the starter from the ignition switch when you are trying to start it.
Post what you find out.
Old 30 Apr 2017, 02:37 pm
From what I read, the problem could be as simple as a fuse, but impossible to diagnose the problem with so little information.
Will not start but does crank?
Does not crank at all?
Cranks, tries to catch and stalls?
Old 01 May 2017, 02:22 pm
when you turn the key, you hear a click but it doesn't start. But all the lights and everything else comes on. Hubs tried to hit it like someone mentioned above but it didn't work
Old 01 May 2017, 03:39 pm
Hitting the started didn't work- you will have Follow
ptcruisersteve Obsessed Cruiser suggestions or find some one that can use a Voltage meter to check for a good ground and 12 volts at the starter.
You can try jumping the starter with another heavy cable directly to the starter from the battery.
73 Charger SE
01 Sebring flip
Old 01 May 2017, 03:53 pm
VsandFords's Avatar
If it "clicks", it could be a bad starter or a bad connection. If the sound is a solid "clunk", I would lean more toward the starter. Kinda hard to diagnose from this keyboard.
Tags
battery, for sale, starter
Stalled while driving, key to start, no click or start farmerhope Tech & Performance Forum 30 08 Feb 2016 03:44 pm
start then die richardvan Tech & Performance Forum 15 28 Jul 2014 07:33 pm
Pt just won't start mattie1972 Tech & Performance Forum 6 19 Aug 2013 09:58 pm
car didn't start in the cold, got jumped then was a bubbling sound and won't start Saqqara Tech & Performance Forum 1 15 Dec 2009 06:35 am
What a way to start the day!! Knotsobright1 General PT Cruiser Discussions 7 06 Oct 2009 12:00 am
