really high idle, rock hard brake pedal
Like Tree14Likes
  • 4 Post By Fk5
  • 2 Post By Handy_Cruiser
  • 3 Post By CREWZIN
  • 1 Post By robadat
  • 4 Post By dethlikesilence
Old 01 May 2017, 12:33 pm
Default really high idle, rock hard brake pedal
Started up my 01 cruiser this morning idle went to almost 3000, then back down to 1500, then kept pinging like i was pushing the gas pedal. Car will do 40 by itself. Brake pedal is rock hard and had to use both feet to stop. Anyone know what's going on?
Old 01 May 2017, 12:50 pm
Fk5 Fk5 is offline
Default Re: really high idle, rock hard brake pedal
First!
Check the vacuum lines going to your brake booster. Lack of vacuum would make your pedal hard, the leak will make the idle race. There is a big hose there that people knock off when doing work. Sometimes they knock a cap off or the hose just tears from age. Good luck.
2003 GT 5 speed
162,000 miles
Old 01 May 2017, 12:55 pm
Handy_Cruiser's Avatar
Sounds like a classic mass vacuum leak.
This is one where trouble codes may not mean much at first. Just note what they are for now. The only exception might be an EGR code of some type.
If me, I'd first inspect the 3/8th inch rubber hose running from the back of upper intake manifold to the brake booster. The most likely thing is that this hose and either come loose or the check valve the hose attaches too at the brake booster has come loose or is broken.
If it's still attached, there's no strong sucking sound when running, and the PVC hose return hose on the front left (drivers) side of the upper intake looks good, I'd take the hose loose from the brake booster and plug it. If the engine runs good, then you know there's a likely failure within the brake booster itself.
Also, look for cracks in the intake manifold and anything else that would let a lot of air get sucked in from somewhere other than the throttle body. If no joy let us know what trouble code you have and we will try some other things.
VsandFords and rsrocket1 like this.
Old 01 May 2017, 01:06 pm
Had the same problem a few months back. As the other said: vacuum leak. Follow the big hose from the Brake Booster where it goes to a "T" and them to smaller hoses. Make sure they are all good and making good connection.
Old 01 May 2017, 01:39 pm
Originally Posted by Fk5 View Post
First!
I've accidently knocked that hose off more than once.
Work on the car, start the car up, and it races to 3000 rpm... I then pop the hood and put the hose back where it belongs, car goes back to purring like a kitten...
rsrocket1 likes this.
Old 01 May 2017, 01:40 pm
VsandFords's Avatar
+1 on ALL of the responses.
Old 01 May 2017, 05:26 pm
Thumbs up Re: really high idle, rock hard brake pedal
Thank you to everyone for the information. I'm sick like a dog right now, but hopefully tomorrow if I feel better I will look and let you know!
Old 01 May 2017, 05:35 pm
Curiosity got the best of me, the big hose that comes from the booster was unplugged from the intake manifold. Slid in kinda loose, back to normal. I greatly appreciate your help and support! Thank you!
Old 02 May 2017, 10:07 am
One of these days I really should put a hose clamp on that damn hose... I knocked it off again topping off the coolant last night...must've brushed against it with coolant jug...
Left brake light won't work when pressing down brake pedal ReeseBear Tech & Performance Forum 9 16 Dec 2016 01:39 pm
Hard brake pedal edscrz General PT Cruiser Discussions 8 25 Feb 2013 07:22 pm
replacement gas pedal and brake pedal?? legion Interior Accessories Forum 7 17 Jun 2004 10:06 am
Awards dinner at the Hard Rock Cafe RED N BLACK Southeast PT Forum 0 03 Oct 2003 08:45 pm
