Correct block and head to rebuild
Old 08 May 2017, 05:01 pm
Default Correct block and head to rebuild
I have a 2005 2.4L Turbo HO engine. The one with the plastic intake. I have been told I need the engine rebuilt and the head done.
If I got another block and head to rebuild to put in place of the original engine what block and head should I look for.
Can it be a non-turbo block or a turbo block or does it need to be a HO turbo block. Same with the head.
Any other comments would also be welcome. Thanks.
Old 08 May 2017, 06:00 pm
Default Re: Correct block and head to rebuild
I believe the Turbo engine block is unique to the Turbo cars. Heads may be the same as n/a engines.
Advice: Warped Head/gasket or Cracked Block? Daddie0 Tech & Performance Forum 19 18 May 2015 05:21 pm
Block Tester, blown head gasket lmarkie74 Tech & Performance Forum 8 15 Feb 2014 10:55 am
head or block samsonhusky Tech & Performance Forum 18 13 Jun 2013 10:41 am
2001 head on a 2003 block would it work. rlspiegel Tech & Performance Forum 1 29 Feb 2012 04:52 pm
Cracked Block or Bad Head Gasket? shadowsnkx Tech & Performance Forum 22 25 Aug 2011 10:07 pm
