Oil Leaking from Dip Stick Tube
  • 1 Post By Fk5
Old 09 May 2017, 05:05 pm
Default Oil Leaking from Dip Stick Tube
Hey Guys.
While changing the oil on my wife's PT Cruiser this weekend, I noticed a buildup of oil and dirt around the bottom of the dipstick. It looks like it has been slowly leaking over time. Is there a gasket or an o-ring where the tube meets the oil pan? There is a gasket on my Colorado, but I do not see any parts listed for the Cruiser. Also, what holds in the dipstick? There is a bolt on top and I think I can feel a nut holding it down to the oil pan.
Car: 2004 PT, non-turbo, about 130k miles. Seamist Green Metallic
Thanks!
Old 09 May 2017, 05:47 pm
Fk5 Fk5 is offline
Default Re: Oil Leaking from Dip Stick Tube
Originally Posted by TheDrew View Post
Hey Guys.
Thanks!
I'm pretty sure it is just a press fit with the bolt holding it to the intake so it doesn't flap around. They go in a few inches, so there is no reason it would need a gasket not to leak. I think it is just a good place for grunge to buildup and it is more likely a leak from above.
JoeX likes this.
2003 GT 5 speed
162,000 miles
Old 09 May 2017, 07:05 pm
VsandFords's Avatar
It sounds normal to me. It takes a very small amount of oil to collect a lot of dirt.
Old 11 May 2017, 01:52 pm
I will take a look again, you could be right about just collection point for a few drops. It had a decent layer of mostly dirt with oil sludge around it. I will continue to monitor to see if I can track down the source of the leak.
Thanks!
quick question 04 pt leaking alot of water out of moisture tube ac off strokedoutss General Turbo Discussions 9 28 Nov 2012 03:10 pm
Broke oil dip stick tube DODGETHIS Tech & Performance Forum 10 03 Apr 2012 03:03 pm
Stick it in your>>>>>> turbomangt General PT Cruiser Discussions 5 19 Aug 2003 07:58 pm
