2006 PT Overheating issues
Like Tree5Likes
Old 16 May 2017, 07:08 pm
Default 2006 PT Overheating issues
Ok I'm about done with this car. It's been nothing but problems. This is my last resort before I junk it. It randomly overheated about 3 weeks ago. So Let me tell you exactly what I've done since then :
Replaced coolant
Replaced Radiator Cap
Replaced Radiator
Replaced Radiator Fan
Replaced Head Gasket
Replaced spark plugs and spark plug connectors
Replaced Water pump
Replaced both motor mounts
Checked all fluids and made sure all were fine (including freon for AC)
Car ran fine for exactly 45 mins. Then for no reason, it overheated again and there's a "bubbling" sound I think from the Overflow. Radiator works, Fans work, AC works, but it keeps running hot.
Does anyone have any clue what it could be before I junk this thing?
wingman55 likes this.
Old 16 May 2017, 08:21 pm
wingman55's Avatar
Default Re: 2006 PT Overheating issues
You probably did, but just in case, did you check to make sure that the fan(s) actually came on? Could be a fan relay, or wiring.
Just a thought.
2006 Limited Edition, Inferno Red, 5-speed, Bassani dual exhaust, Chrome backup light bezels, taillight trim, fuel door, antenna mount, Ventiports, door spear covers & hood prop. Silver painted lower front grille. American Racing 383 Casino wheels, w/Chrysler emblems, '02 engine cover, PT Cruiser mudguards, cargo mat. EGR Window Visors, dark gray lock pulls, dual horns, Fuzzy Dice, flames and MOPAR emblems added to front door logos, gold Chrysler emblem on rear hatch. Upgraded to RAK radio with 6 CD changer, Cassette Tape and RDS info. Name: "FIREBALL" I bought it Aug 10, 2015, with just over 35,600 miles on it.
Old 16 May 2017, 09:41 pm
Does it overheat at both low speeds and high speeds ?
Old 17 May 2017, 02:15 am
@wingman Yes the fans are working 100%. I even just checked again for air in the engine thinking it might be a random bubble or something. It ran fine again for exactly 45mins to an hour, then the Temp gauge went from the 1/2 way point to 3/4 and finally overheating. So turned it off again and checked everything I could think of.
@PTcruisersteve It only overheated the first time going 25 mph up a hill.. Then it happened again when I was on the same hill slowing down to park but this time instead of facing up, I was going down the hill.
The only two things I can think of its my TIPM (Which is faulty because I can't get my regular beams to turn on) is causing a problem or the Temp Gauge sensor is bad?
I just drove it again up and down a high way for an hour and nothing until I went to park. It went up to 3/4's again on Temp Gauge and now there's a "gurgling bubbling" sound I've never heard before. I'm at my wits end with this car.
Old 17 May 2017, 06:32 am
I'd try removing the intake and valve cover and re-torking the head bolts.
Was the head checked to see if it was warped before installation?
Was this engine severely overheated before parts were replaced?
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 17 May 2017, 07:04 am
JDK52's Avatar
With all the work you have done to make this right, it is easy to see why you are angry!
In your list of replaced parts I did not see a thermostat.
Even if the thermostat was replaced, sometimes new are defective.
If all else has been tried, I might perform one of those chemical tests on the coolant to detect a failed head gasket.
Good luck.
Old 17 May 2017, 07:33 am
rsrocket1's Avatar
Never mind.
I wanted to welcome you and encourage you to introduce yourself since you don't show anything on your profile. Then I looked up your previous posts.
Looks like every time you start a thread you are about to give up on this car
Did you ever get your camshaft sensor problem fixed from 2011?
You never replied whether or not the help given here fixed it
Did you ever get your grinding noise problem fixed from 2012?
Did you ever get you headlight problem fixed from 2013?
Did you ever get your crankshaft sensor problem fixed from 2015?
JonN likes this.
Old 18 May 2017, 02:14 am
Originally Posted by rsrocket1 View Post
Never mind.
You never replied whether or not the help given here fixed it I lost those threads LONG ago. Camshaft sensor has been replaced yearly since 2011 WITH the crankshaft sensor. Mopar , dealer parts, or something from Autozone they keep failing
You never replied whether or not the help given here fixed it Grinding noise was the idiots at Midas messing up a caliper when they rotated my tire. The replaced everything
You never replied whether or not the help given here fixed it. Nothing fixed the headlights. They are still non functional. Dealer tired a new TIPM, flashed it , they didn't turn on. They said "It'll probably be another $1200 to take the dash apart and find whatever electrical problem is causing all this." I declined and I just drive around with brights on.
You never replied whether or not the help given here fixed it Crankshaft had to be replaced yearly along with Camshaft.
This car has quite literally been the worst car I've ever owned. It's always in need of something repaired every 3-5 months like clockwork.. I got it in 2007, one week after I got it, my drivers side window fell in the door. The dealer said it was "Defective" and replaced the door.
2008 Less than a year of having it, front drivers side tie rod broke.
2009 First camshaft / crankshaft sensor replaced
2009 Back windshield wiper won't turn on
2010 Front windshield wipers won't turn off
2010 two lugnuts just "fell off"
2010 First battery dies
2011-2017 some of the problems listed above not to mention replaced every sensor on the car, AC problems, Back windshield wiper is dead again, exhaust had to be replaced completely and i can't open the passenger side door from the inside.
This car is extremely unreliable. I'm not one of those people who doesn't get it serviced ether. I always get it routinely looked at.
Old 18 May 2017, 02:18 am
Good luck.
We did replace the Thermostat. I guess I'll have to check that to see what's up. Didn't think about trying a chemical test. It randomly overheated again today this time at 60 mph going up an on ramp. When I finally got it cooled down enough to drive it home at night it did not over heat, however it still making a "gurgling / bubbling" sound when i turn it off. There is no spillage or leaking overflow. Coolant did not spill out... I'm literally out of ideas of what it could be. The only think I can think of is maybe the Temp Sensor is faulty? Or the TIPM is making the Temp Sensor faulty? It couldn't be a Temp Relay could it?
Old 18 May 2017, 02:26 am
I'll try the intake / valve cover tomorrow and update once i see if it change anything.
I honestly don't know if they check for a warped head before it was changed. I'll call tomorrow. That's the only thing I did not do with my uncle who's a mechanic ourselves.
The engine had zero problems until I got my entire exhaust changed. A part fell off, so I just got it all replaced. The first overheat was before that. It just randomly overheated and all of the coolant shot out of the overflow. I put more in, checked for air, and drove 20 mins home and it did the same thing. Midas checked the lines for pressure, used the bleeder valve and said everything was fine after they changed the exhaust.
Every since then we changed all the parts listed in the original post.
I'm down to TIPM, Temp Sensor, or Temp Relay are my only logical guesses left. I don't want to keep throwing money into this car if all of those don't fix anything. I don't think the head gasket is warped but that will be a deal breaker if it is. I"m not paying $1k for that repair. That's the average of most local shops. I'd rather spend that money on a new car that actually runs.
Tags
2006 pt cruiser, overheating engine, overheating problems
Overheating and Other Issues deprivedwriter Tech & Performance Forum 8 16 Aug 2015 03:31 pm
Overheating issues SamanthaB Tech & Performance Forum 5 13 Apr 2014 09:00 am
overheating issues - again :( Garya1682 Europe PT Forum 12 02 Aug 2013 02:14 am
Overheating issues jkdrummer Tech & Performance Forum 3 25 Jun 2012 09:36 pm
My PT is overheating and now other issues ptcruising Tech & Performance Forum 4 10 May 2012 10:56 pm
