Changed both O2 sensors and still getting their codes.
Like Tree5Likes
Old 17 May 2017, 05:37 pm
War_Eagle's Avatar
Default Changed both O2 sensors and still getting their codes.
I replaced both O2 sensors after my CEL came on and the car started to hesitate, idle rough and stall. I put the reader on it, showing O2 sensors bank 1 and 2. After replacing them, I cleared the codes through the reader but the light comes back on and the problems are still happening. The only codes I am getting are for O2 sensors bank 1 and 2. This is driving me nuts, does anyone have any ideas?
TAMMYPT likes this.
2005 Silver GT, auto, black leather, HID Headlights, ST Front sway bar, 215 45/17 tires, dark tinted front windows, stock running gear, sickspeed black pearl shift knob.
Old 17 May 2017, 05:38 pm
Default Re: Changed both O2 sensors and still getting their codes.
What are the actual engine trouble codes you are getting?
Old 17 May 2017, 05:41 pm
Bad grounds on the left fender could be the culprit. Just because they are crimped to the eyelet is no indication the ground is good.
TAMMYPT likes this.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 17 May 2017, 09:52 pm
Both H02s replaced and still getting DTC may mean a PCM issues.
You would need to replace the PCM
Old 18 May 2017, 02:40 pm
WrenchnIswhatIdo's Avatar
I'm no expert But /\ /\ This guy /\ /\
knows a thing or too and his advice speaks volumes
I bet good money on it and have ....and will.....W..
NitroPT likes this.
Originally Posted by Canadian Moose View Post
Just answer one simple question. Do you own any of the following?: Opel, Alfa Romeo, Fiat, Lada, Yugo, Kia, Daewoo, Volvo, SAAB, Jaguar, Land Rover, Chrysler, Dodge, Plymouth, Jeep, Lancia.
If you answered “yes” then parts car is a really good idea.
Old 19 May 2017, 05:18 am
You need to look into what the o2's are telling you. Lean/ rich. If both banks chances are you have a effecting the whole engine. My money is on a vacuum leak but just a guess. The systems needs to be diagnosed you already did the parts swap.
Check for broken vacuum lines. Listen for hissing and see if you can locate where it is coming from. You can try to blow smoke through the vacuum line going to the power brake booster and see if you see any smoke coming from the engine.
Good luck
Old 19 May 2017, 08:47 am
A Thought. ^^
If you pull a line, lets say a BIG one like the PCV I doubt you would activate a DTC having to do with the H02 after the engine has warmed up let alone 2.
Now if you had an exhaust manifold leak at the head or very close to the H02s perhaps?
Old 19 May 2017, 12:53 pm
War_Eagle's Avatar
Codes are 0031 and 0037. I also have an 0700 transmission code.
Old 19 May 2017, 01:15 pm
We have found that the recurring EDT in a PT Cruiser PCM even after changing both HO2s and also new existing TCM warnings that the PCM may be in a state of issue.
We will usually do a pass through or flash to see if this resolves the problem. If we know that no engine work has recently been done that any wiring harness or wires could have been damaged than the suspect generally is the PCM.
I seem to be repeating myself so time for me to exit this thread.
unless I need to defend my responses
Hope you resolve it soon and with the least expense to resolve the problem.
Old 19 May 2017, 05:20 pm
These codes are very common and especially prevalent on the turbo Pts. Don't waste your money trying to flash it to fix it. It seems that the poor air circulation under the hood, and the close proximity to the high heat generated by the turbo, cooks the ECU. The O2 circuits seem to be most prone to this high heat and those circuits fail first.
Exhaust all other diagnostic trouble shooting first to see if it could possibly be something easy like a vacuum leak or poor grounds, but be prepared to be buying a new/used replacement ECU.
o2 sensor codes after changing o2 sensors? Wrexxin_97 Tech & Performance Forum 22 01 Nov 2016 04:25 pm
WhatElseShould Be Changed When Timing Belt Is Changed? myjeephatesme Tech & Performance Forum 5 02 Jun 2014 01:51 pm
Codes, codes, codes... Desperately need engine light help... cdc3jj General PT Cruiser Discussions 9 01 Sep 2012 07:52 am
O2 Sensors? Georgiachick86 Tech & Performance Forum 5 25 Jul 2011 05:54 pm
more error codes after new input/output sensors swordfish Tech & Performance Forum 0 07 Jul 2010 12:05 pm
