Intermitant not getting spark.
Old 20 May 2017, 11:48 am
Default Intermitant not getting spark.
2002 PT Cruiser 2.4L Check engine light does not come on.
Started a few weeks ago. It is getting worse. Sometimes it gets no spark at all. Up til today, never stopped in traffic. Hooked up to timing light. Light flashes, it starts right up. But, when it does not start, there is no flash at all from timing light. Stop cranking, try again, no flash from light, no start. Repeat 5 to ten times, as soon as timing light flashes it starts right up. So intermittently it gets no spark and getting more often, now even dieing in traffic but finally started up and drove it home. Is a sensor giving out? What is most likely cause? Help?
Old 20 May 2017, 12:36 pm
Default Re: Intermitant not getting spark.
Welcome to the forum
You should go and start a thread to introduce yourself and tell us a little about your PT Cruiser.
WELCOME and Forum Rules
We encourage all new members to say hello and introduce yourself to the rest of the community by starting a post in the Welcome New PT Owners thread at the top half of the forum.
As for your question, try to take a little more time looking on our long established forum to start looking for solutions.
Old 31 May 2017, 05:30 pm
a weak link on Chrysler products is the crankshaft position sensor, and a lot of Chrysler's have a problem with the after market sensors,I would go with an OE part
Old 31 May 2017, 06:42 pm
Check the wiring harness underneath the engine from the cr
Ankshaft sensor and camshaft sensor to
PCM. Sometimes harness hook breaks and wire h
Arness rubs on axle.
Battery Draw Down, intermitant Parasitic? CycletoCycle Tech & Performance Forum 10 23 Jul 2013 06:51 am
Intermitant AC Fifty4F100 Tech & Performance Forum 2 04 Jun 2013 09:48 pm
Intermitant power. daviesl771 Europe PT Forum 5 31 Dec 2012 03:04 pm
05 pt intermitant missfire bobrat Tech & Performance Forum 3 19 Aug 2011 10:10 pm
Spark pulgs and spark plug wires? balvarez814 Tech & Performance Forum 1 13 Aug 2008 08:16 pm
