2006 A/C expansion valve/orifice?
Old 20 May 2017, 05:35 pm
Default 2006 A/C expansion valve/orifice?
Does the 2006 PTC use an expansion valve or orifice? Where is it located? Thanks.
Old 20 May 2017, 06:19 pm
Default Re: 2006 A/C expansion valve/orifice?
This should answer the first part of your question.
4Seasons/Everco A/C Hose Assembly 56832 - Read Reviews on 4Seasons/Everco #56832
Old 20 May 2017, 07:41 pm
Thanks, that answers both questions.
Now the trick part: how do you replace the hose? The part on top is easy, but the other end goes into the lower port of the condenser. The only way I can see to stick my arm down there is to take out both upper and lower intake manifold. That can't be, can it? Don't think I can get to it from the bottom either.
Old 20 May 2017, 07:43 pm
Sorry, not sure how to replace it. Never had to. Maybe someone will come along with experience on that work.
Old 31 May 2017, 05:28 pm
why do you want to replace the expansion valve?? I would test it first, if you turn air on and have a gauge on the low suction side line, then rev engine, if the reading goes to 0 then the expansion block is defective
▀█► A/C expansion valve location? 2006 PT Cruiser Touring Edition ken2028 Tech & Performance Forum 2 07 Jul 2013 03:55 pm
PT Cruiser 2002 AC Expansion Valve? larcoelho Tech & Performance Forum 1 23 Aug 2012 05:05 pm
AC orifice tube fastone General PT Cruiser Discussions 1 25 Jun 2012 02:19 pm
Orifice tube tbcrusier Tech & Performance Forum 3 13 Apr 2012 08:38 pm
A/C expansion valve location? pppt03turbo Tech & Performance Forum 8 10 Aug 2011 12:37 am
