2007 PT Cruiser Air Conditioning not working
Old 28 May 2017, 07:40 pm
Default 2007 PT Cruiser Air Conditioning not working
Hi all, I am new here..
I have a 2007 PT, non Turbo. The cold air stopped working on it about a year or so ago.
I tried recharging the freon and noticed the gauge on the freeon kit wavers back and forth. Meaning it doesnt stay in the full (green) area it goes to green saying its full then it drops to the empty area on the gauge.
I checked to see if the compressor is working and I can hear it clicking on and off.
I took a shot in the dark and replaced the Low Pressure Valve to see if that was the problem and it still doesn't blow cold air.
Any help would be greatly appreciated.
Old 29 May 2017, 06:18 am
Default Re: 2007 PT Cruiser Air Conditioning not working
While I don't know diddly about a/c, it sounds to me like you've got a hole in the system somewhere. First thing I'd check is the a/c hoses around the crimp connections for any obvious signs of leakage. If they look clean, then you need to remove your grille and check the condensor for holes.
Old 29 May 2017, 07:20 am
VsandFords's Avatar
Welcome to the forum from Texas.
You might check with the auto repair shops in your area. They sometimes will run A/C specials this time of year. You might be able to have them check the system and let you know what's wrong for only an hour labor or less. A friend had a facebook special last year, $35 to check and charge system.
Old 29 May 2017, 08:09 pm
magoo28630's Avatar
HI
is your fan running when you turn the air on? I mean the radiator fan. If its not that could be the problem.
Magoo
06 limited turbo lite Autmatic 104k Magnesium Pearl
Not sure about how many owners.I think I'm the third owner. Purchased February 2017.
Changed engine oil and Trans filter and fluid.
Changed the washer nozzles.
Waiting for the weather to change and Then I will change the timing belt and water pump, Motor Mounts All. Brakes. Bell crank. and I am sure I will find other little things to change.
I love this car! it's the only car I have ever gone looking for. instead of just looking for best used car at the best price. magoo NC
Old 31 May 2017, 05:03 pm
did you pull a vacuum on the system before adding freon?? if not, air takes up space,and you didn't have enough room for the factory spec charge to go into system, the system has to be evacuated first,then add (2) cans of R-134-A to it, the PT's hold 24 ounces of freon
2007 PT Cruiser key fobs both stopped working LM3 Tech & Performance Forum 9 10 Apr 2018 10:15 pm
2007 PT Cruiser key fobs both stopped working LM3 Sound and Security Forum 8 28 Mar 2017 06:49 pm
2007 PT Convertable Door locks not working emwatkins General PT Cruiser Discussions 1 08 Dec 2013 11:09 pm
PT Cruiser Air Conditioning Problem Carter Tech & Performance Forum 2 09 Aug 2011 07:03 am
air conditioning not working Gigi89 Tech & Performance Forum 3 05 Jun 2009 07:30 pm
