problem shifting gears
Old 30 May 2017, 03:22 pm
Default problem shifting gears
I have PT Cruiser 2002 1.6 benzine engine and I have difficulties shifting gears when car warms up (it seems to me and maybe I am wrong but it gets worse when I turn on air conditioning) Anyways I then need to press really hard on stick shift to move gear to the next position. Once the car cools down shifting becomes easier. When the engine is turned off shifting is normal.
Old 30 May 2017, 04:39 pm
rob302's Avatar
Default Re: problem shifting gears
try adjusting the clutch-master adjusting rod under the dashboard ...on the firewall. see here:
Stiff transmission when hot?
Old 30 May 2017, 04:42 pm
rob302's Avatar
this is what you're going to adjust (lay on the drivers side floormat and look up):
we get this problem posted here almost daily this time of year. you're the first one of the new year
loosen that nut, pull the pedal up, then tighten the nut.
post your results. it'll very likely be fixed
Old 31 May 2017, 05:02 am
Thanks for quick reply. Will try to do this on weekend and will post the result
Problem shifting sweetmaureen Tech & Performance Forum 2 03 Apr 2016 01:26 pm
'06 odd shifting problem SilverGT06 General PT Cruiser Discussions 8 01 Mar 2016 09:31 am
shifting automatic transmission problem white2011 Tech & Performance Forum 4 03 May 2015 05:48 pm
Transmission shifting in to low gear problem karleton General PT Cruiser Discussions 9 20 Aug 2010 01:15 pm
Education Is Shifting Gears skylight PT Cruiser News and Rumors 0 14 May 2007 06:30 am
