Cranks, but not starting :(
Like Tree3Likes
  • 1 Post By chuzz
  • 2 Post By JoeX
Old 31 May 2017, 07:27 pm
JWHF25's Avatar
Default Cranks, but not starting :(
Got in it earlier and it started right up fine, put it in reverse and got about 1 foot then the rpm went really low and it died. Radio was still playing, lights work fine, but wont start. Its cranks but just doesnt start now. Looked up under the hood and everything looks fine and its full of gas, but in all honesty I have no idea where to begin.
2006 regular 2.4l.
Old 31 May 2017, 07:57 pm
Default Re: Cranks, but not starting :(
Did you Check Engine Light come on?
Post the codes
What year is the car
Milles on the car?
List any maint you have completed
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 31 May 2017, 08:31 pm
JWHF25's Avatar
The check engine light is on, but how do I get the codes?
160k miles and the maintenance has pretty much been straight with the maintenance schedule in the owners manual.
Old 31 May 2017, 08:39 pm
JWHF25's Avatar
I googled it and mine went ----- Done and then back to my mileage. It didnt give an error code.
Old 31 May 2017, 08:40 pm
JWHF25's Avatar
This is the video I watched and mine did the exact same.
Old 31 May 2017, 08:42 pm
Using the key dance to get the engine trouble codes is not the best way. The best way is to get an OBDII Scan Tool but for now you can do the steps below.
1. Place the key into the ignition.
2. Turn the key towards the windshield (without starting the engine) and back again.
3. Do the above 3 times and with the last turn the key left pointing forward (towards the windshield).
4. All three turns should be made within 5 seconds. (it's not hard).
If you did it right, in the middle dial where the odometer is, the fault codes stored in the computer will come up. Example: P0138
If there's no codes stored in the computer, it should read "done".
Old 31 May 2017, 08:47 pm
i would suggest if you have no codes to spray starter fluid in the throttle body with it wide open and see if it starts to run.
Old 01 Jun 2017, 06:37 am
You need 4 things to make your engine start. Fuel, spark, compression and air. Check each one and get back to us. That is, after running codes and having your battery checked.
Old 01 Jun 2017, 06:57 am
Some things are not monitored, one of them is fuel pressure. If the fuel pump goes bad, fuse blows, or you lose the ground to the pump it will quit pumping, no code, no start.
Please correct me if you need to. Just my thoughts
73 Charger SE
01 Sebring flip
Old 01 Jun 2017, 03:39 pm
JWHF25's Avatar
Ok, Thank you all!!
06 PT cranks no start drumrooster Tech & Performance Forum 36 25 Feb 2017 09:22 am
Cranks, won't start (bad PCM ???) dxv77 General PT Cruiser Discussions 14 26 Jul 2015 05:19 pm
05 PT cranks but won't start. Noah1 Tech & Performance Forum 5 22 Jan 2015 03:38 am
cranks no fire brendajrohr Tech & Performance Forum 3 07 Dec 2014 06:52 pm
Cranks but want start stickkman99 General PT Cruiser Discussions 8 04 Aug 2013 12:00 am
