Burning smell, steering wheel shakes
Like Tree5Likes
Old 01 Jun 2017, 11:00 am
Default Burning smell, steering wheel shakes
I have an 08 manual transmission PT Cruiser, 85k miles.
Yesterday driving home from work my steering wheel was mildly shaking, as if a tire is out of balance. I pulled over to see if I had a flat tire, which I did not. I noticed a significant burning smell. I drove the car again, and let it coast. When coasting, it felt as if something were catching at a portion of each revolution of the wheels, sort of like when a brake pad on a bicycle catches on a bent portion of the bicycle wheel rim.
I drove slowly and the buning smell continued, and the car just didn't feel right.
I took it to a tire store, and they said they drove it for 30 minutes today and found no problems. They said I could replace the rotors and calipers as the rotors are worn down, but that this may not be the problem.
I don't want to invest in the rotors and calipers, should I just keep driving it and see how it goes, or take to another shop for second look?
Thanks for any replies
Old 01 Jun 2017, 11:09 am
Handy_Cruiser's Avatar
Default Re: Burning smell, steering wheel shakes
From what you described this could be anything from a collapsed rubber brake hose to a bad wheel bearing. Don't let a shop just default to brakes, calipers and rotors because the shop you went to can't find the problem.
You likely need to take your PT somewhere else where they can do a better job of diagnosing your issue. And yes, sometimes these problems come and go. But a good mechanic can likely find the issue.
Old 01 Jun 2017, 03:03 pm
I would suggest checking to make sure your CV booths are not leaking. If they are leaking they can start burning on the rotors.
Old 01 Jun 2017, 05:43 pm
Fk5 Fk5 is offline
Usually I just get out and spit on the wheels. The one that instantly boils is the one to check out.
2003 GT 5 speed
162,000 miles
Old 01 Jun 2017, 07:43 pm
You should have ittaken care of immediately as it can be a safetyissue.
Old 01 Jun 2017, 07:51 pm
I took it to another mechanic who said that as the weather heats up the (i may have some of this wrong) line that feeds the brake is altered or melted and causes the brake to apply to the right front wheel. He said when it happens to stop the car and let it cool down for about 20 minutes. He recommends a fix that costs about $350, I don't recall exactly what the fix is, but something like a caliper fix and associated parts (I think new pads were included). He said it will probably continue to happen. Does that price sound good?
Old 02 Jun 2017, 06:21 am
Steer clear of that clown. A brake hose is probably all he's going to replace and MAYBE remove the caliper guide pins and clean and lube them. Most of your auto parts stores sell them in the $20-$25 range. Do it yourself and save!!!!
Old 02 Jun 2017, 07:39 am
I wonder why he wants to replace more than just the hose?
Old 02 Jun 2017, 07:52 am
Fk5 Fk5 is offline
I am not sure why you are calling the guy a clown. The OP is obviously not much of DIY'er. Their original mechanic didn't even suggest the brake hose and wanted to do a full brake job (rotors/calipers) without mentioning the hose which seems the most likely cause.
Plenty of shops aren't going to want to do a brake hose and then put beat up pads back on and a reluctant owner isn't so likely to do a great job. A brake hose is a fairly easy DIY, but if the OP isn't interested in reading up, do you think that bleeding the brakes and setting the calipers up is going to be that easy for them?
creflo likes this.
2003 GT 5 speed
162,000 miles
Old 02 Jun 2017, 08:07 am
I think that Chuzz was just trying to make a statement of how to keep the cost of the repair down even further and not personally attacking the mechanic.
creflo likes this.
Struggling to accelerate/burning smell when its hot outside Subjekt_9 Tech & Performance Forum 10 23 Oct 2018 07:49 am
battery light and burning rubber smell thaddues63 General PT Cruiser Discussions 5 14 Jun 2016 05:07 pm
Electrical Burning Smell and Smoke from Under Hood ktheater Tech & Performance Forum 3 11 Nov 2011 03:31 pm
Engine and steering Wheel Shakes in reverse Blue2002cruiser Tech & Performance Forum 1 26 Mar 2011 06:49 pm
Steering Wheel Shakes/Vibrates at 60+ MPH paulrosenthal Tech & Performance Forum 11 24 Apr 2010 04:14 pm
