08 Pt Cruiser_Passenger front door does not open from inside
Like Tree4Likes
  • 1 Post By rckstein
  • 2 Post By lucasrotondo
  • 1 Post By ptcruisersteve
Old 01 Jun 2017, 04:02 pm
Default 08 Pt Cruiser_Passenger front door does not open from inside
Hi folk, I do need your help, I've a 08' PT Cruiser. Passenger front door cannot be opened from inside. When I pull the latch some times the door opens but mostly not. In my opinion it seems to be an electrical problem, cause from outside door always open. I would like to take door cover out and check wires and connectors.
Please, I really appreciate any suggestion before doing sthg.
Many Thanks!!!!
Lucas.
Old 01 Jun 2017, 04:12 pm
rckstein's Avatar
Default Re: 08 Pt Cruiser_Passenger front door does not open from inside
Welcome to the forum
It's a mechanical connection between the inside latch handle and the latch mechanism, not electrical.
In the pic below, this tech has his hand on the latch rod that attaches to the inside door handle:
There is a little clip on the inside of the latch handle that holds the rod, these clips may break.
You'll have to pull off the door panel to see what's going on.
This video will show you how to remove the door panel, he doesn't do a good job of showing the inside of the door panel, but once you remove the panel, you'll see the clip on the rod, just flip it down to unlock it off the rod and you will have to unclip the wire connector for the lock switch, really easy:
Old 14 Jun 2017, 07:15 pm
Hi rckstein, many thanks for your help!
I've solved this problem. I've just pulled door panel off like the video explanation and following your instructions. I found no broken parts, it was pretty simple, rod lost its form by the use. So, I adjusted its form a little bit until the latch handle worked properly again.
Best Regards, Lucas.
Old 14 Jun 2017, 07:25 pm
rckstein's Avatar
Glad to hear you got it fixed, and it didn't cost you anything, except a little bit of time
Old 14 Jun 2017, 07:26 pm
Thanks for posting what the problem was.
rckstein likes this.
Tags
door problems
Can't open driver's door from inside PTDarryl General PT Cruiser Discussions 3 01 Jun 2017 04:08 pm
Front Door Inside Handle link - 2001 Cruiser MikeGlosta General PT Cruiser Discussions 4 06 Sep 2016 11:58 am
Rear door won't open from inside Shiniquiet General PT Cruiser Discussions 11 02 Oct 2011 11:24 am
rear door won't open from inside or outside robynlr Tech & Performance Forum 3 22 Apr 2011 01:44 am
Rear door doesn't open from the inside pjkokopelli General PT Cruiser Discussions 6 01 Jul 2008 05:40 pm
