Steering racks
Like Tree2Likes
  • 1 Post By rob302
  • 1 Post By rckstein
Old 02 Jun 2017, 08:03 pm
Default Steering racks
I need to replace the steering rack in my 2006 Limited, manual, non-turbo. Most vendors list several different parts, one of the choices being with or w/o sensor.
Are the racks the same and a matter of including the sensor, or are there 2 different racks? How do I determine if I have/need the rack that comes with the sensor or the other one? Thx.
Old 02 Jun 2017, 08:40 pm
rckstein's Avatar
Default Re: Steering racks
You can call your local dealership and using the VIN for your PT, they can give you the correct and current part number for the rack. You can then use that MOPAR part number to search online for the rack. They should also be able to tell you if the rack on your PT has the sensor or not.
Or
You can go to your local dealership and give them the VIN for your PT, they can then print the Build Sheet for your PT. This Build Sheet will then give you the 3 letter codes for everything that was installed on your PT when it was built:
This is part of the Build Sheet for my PT:
The Build Sheet above shows that my PT has the "SBA" Rack.
Using this info, I can go to say the RockAuto website and search for the part:
They use the 3 letter code on their website and the correct rack for my PT does not have the sensor.
But the Build Sheet is kind of neat info to have.
Old 02 Jun 2017, 08:53 pm
rob302's Avatar
there is a great thread here from our resident wiring expert. he deleted his post while he was understandably angered about a political thread, but i've restored it just for you. you can find it here:
Turning radius data for various PT models
the difference in turning radius's is due to travel limiting spacers installed in the rack(literally cheap, plastic donuts). this was done to limit the amount the wheels turned. they limited the steering a little for fatter auto trans's, they limited the steering more for GT's due to larger rims so they didn't scrape or rub the body/fenders. the 06 was weird with the pressure sensor. most years had it and its purpose was to tell the ECU the PS pump was creating drag so the car could compensate and keep a stable idle speed while under load from the steering pump. some 06's don't have the sensor, so you'll need to either crawl down there and look, or be safe and buy a rack with the sensor, and leave it unhooked.
hope this helps
Old 02 Jun 2017, 11:32 pm
Rob, let me see if I understand you correctly. So the racks with and without a sensor are identical except for the sensor. And so I'm safe by getting one with a sensor.
Do I have it right? Also, where exactly is the sensor mounted?
Old 03 Jun 2017, 12:01 am
rckstein's Avatar
#4 in this pic:
If you crawl under your PT on the drivers side behind the front wheel, the pressure switch, if the rack has one, will be on the back side of the rack.
Old 03 Jun 2017, 01:16 am
Excellent, thank you.
Old 03 Jun 2017, 08:04 am
That's something that I had never done until last year when I replaced mine. It took me about 5 hours, but I didn't have any help. If I had, I probably could have shaved an hour off because when I put the steering column connector back through the hole in the floorboard, I got it stuck between the carpet and firewall and didn't realize it. Took me damn near an hour to figure out why things weren't lining up for me under the car! TAKE YOUR TIME, if you've never done one before.
Three different steering racks for a GT? sawdust123 Turbo Wheels/Suspension/Handling 1 05 Oct 2012 01:09 pm
Accessory Racks/Hitches Morkeste General PT Cruiser Discussions 2 14 Aug 2011 06:42 am
Question on bike racks turbomangt General Turbo Discussions 3 16 Jul 2007 12:50 am
Bike racks for PT spurvis General PT Cruiser Discussions 6 18 Aug 2006 09:10 pm
Bike Racks Ed Lim Exterior Accessories Forum 1 13 Jun 2005 08:28 am
