2006 pt cruiser PCM
  • 1 Post By JoeX
Old 03 Jun 2017, 03:52 pm
Send a message via Yahoo to partyd
Default 2006 pt cruiser PCM
What needs to be done to replace the computer?
Does it need to be reprogrammed with the vehicle VIN number like GM?
Or I can switch it to the vehicle and program the keys?
2008 Pt cruiser Touring
2004 Pt Cruiser GT
2004 Chrysler 300M
2008 Chrysler Pacifica awd
Old 03 Jun 2017, 06:24 pm
Default Re: 2006 pt cruiser PCM
Make certain you need one first, sometimes it just a sensor or ground issue.
What problems are you having, codes???
No the 2006 up models you will need to have your PCm programmed if you find one out of a recycle yard
If you buy one from a company the repairs??? them be careful who you pick but theirs are usually plug and run if its a goood one.
Or If you find a wreck to take parts you will need FOB/Key, key cylinder, skim module, and PCM. After changing the above pieces mine ran. You will have to use a separat door key or get your locks rekeyed, which I DID.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 03 Jun 2017, 06:45 pm
Partyd was working on this issue earlier today.
P2074 CHRYSLER Manifold Pressure
I would consider checking the group of ground wires on the drivers inside fender before considering replacing the PCM. Sometimes they get corroded inside and you can't see it from the outside.
Old 04 Jun 2017, 06:33 am
Why didn't you just pull the door lock and hatch lock too, Joe? They're not that hard to get to.
Old 04 Jun 2017, 06:51 am
I bought off Ebay, locks were not included
chuzz likes this.
73 Charger SE
01 Sebring flip
Old 04 Jun 2017, 09:16 am
I check all the wires, and grounds, I got this vehicle from the auction in 2015 and it was running ok, the fuel pump stop last year and it was the TIPM, after that, it drove good again and now, it idles bad I reset the codes and the check engine lights stays off but driving one block is all it needs to show p2074 again
New sensors, all of them in the intake and cam but still the same
2004 Pt Cruiser GT
2004 Chrysler 300M
Old 04 Jun 2017, 10:29 am
I would suggest using a vacuum gauge for reading, if the belt is off a tooth it will reflect in either a very high idle HG or very low. An engine that is in good condition will idle between 16-18 steady on most 2.4 engines.
Now, depending on your specific year and engine combination, there are updated software available for the engine controller to address this code P2074
assuming there isn't any vacuum leaks. Sometimes the updated software will take care of the problem but please do your own research as I have not experienced this issue myself.
Old 04 Jun 2017, 10:54 am
Good idea, now I need to buy the vacuum gauge, where this connects? to any vacuum hose
This is a 2006 pt cruiser base, plain
Can I use this? It's my old gauge from my Supra
2004 Pt Cruiser GT
2004 Chrysler 300M
Old 04 Jun 2017, 12:18 pm
I would suggest connecting the hand vacuum gauge to the intake manifold either tee into the PCV or the brake hose.
2006 pt cruiser HELP!! YoungGuy Tech & Performance Forum 1 23 Aug 2014 02:51 am
2006 GT Cruiser HO Value? Cyclone General PT Cruiser Discussions 7 16 May 2014 07:33 am
Help please 2006 pt cruiser Ls1216 General PT Cruiser Discussions 3 01 Dec 2012 10:11 pm
2006 pt cruiser need help please!! Ls1216 Tech & Performance Forum 2 01 Dec 2012 04:54 pm
2006 CHRYSLER PT CRUISER AUTOMATIC FACTORY WARRANTY, VERY CLEAN CAR (2006 CHRYSLER PT skylight craigslist 0 15 Jul 2007 01:10 am
