Transmission Pan Bolt Torque
Like Tree4Likes
  • 2 Post By rob302
  • 2 Post By paulwells77
Old 03 Jun 2017, 04:29 pm
Default Transmission Pan Bolt Torque
Anyone have the proper Torque for Transmission Pan Bolts on 05 Turbo?
Also-How do I answer question that is asked by someone replying to my post? Can't find a way.
Thanks,
Paul
Old 03 Jun 2017, 04:43 pm
rckstein's Avatar
Default Re: Transmission Pan Bolt Torque
You already have another thread started for this same issue.
Transmission Oil Pan Torque 05 Turbo
It's best not to have multiple threads for the same issue, confuses other members.
As far as replying to a question, are you referring to your thread on the bent valve diagnosis? You posted a reply in the thread, just be patient and someone will be along that can hopefully assist you.
Engine light on-Bent Valve???
Old 03 Jun 2017, 05:51 pm
Paul,
I've deleted your other post as it was a duplicate to this one. As to your question of answering someones post: under every post there's a blue button that says ( Post Reply). Just click on that button and a new reply page will pop up and you just fill it in with whatever you want and then look for a white button at the bottom of your post that says (Post Reply). Click on that and your reply will be posted in the same thread under the last posted message.
rob302's Avatar
Old 03 Jun 2017, 06:02 pm
rckstein's Avatar
Originally Posted by rob302 View Post
Be careful to notice this spec is in INCH POUNDS
Old 04 Jun 2017, 01:38 pm
Thank you...Semper Fi
Upper Torque Strut Bolt Damaged rcalzadilla Tech & Performance Forum 6 25 Feb 2016 05:39 pm
Head and Cam Bolt Torque specs? Kittysnax Tech & Performance Forum 1 06 Nov 2012 02:35 am
Caliper Mounting Bolt Torque ? Dorkygrin General PT Cruiser Discussions 2 17 Jun 2010 06:15 pm
bolt torque specs?? GTCruiser2003 General Turbo Discussions 1 30 Mar 2004 04:33 pm
third bolt on BOV.....help....torque also ptcruzin42 Stage Turbo Kits 7 26 Aug 2003 10:05 pm
