RADIATOR FAN WONT SPIN !!!
  • 1 Post By chuzz
Old 13 Jun 2017, 03:14 pm
Default RADIATOR FAN WONT SPIN !!!
Hey guys i have a 2001 pt cruiser base model, recently my radiator fan stopped working, i can spin it if i put my hand in there but i wont turn on on its own. i saw that the fan has two relays a rectangular one and a square one, i changed the rectangular one but not the square one, am i wasting my time trying the relays ? is it a blown motor or could it be the other relay ? please help
Old 13 Jun 2017, 03:18 pm
Default Re: RADIATOR FAN WONT SPIN !!!
Need more information.
Is your engine light on? If so do you know what the engine trouble codes are?
Does the radiator fan come on if you turn on the A/C?
Old 13 Jun 2017, 04:19 pm
VsandFords's Avatar
Welcome to the forum from Texas. Please go to the new members section and introduce yourself and your Cruiser.
Old 14 Jun 2017, 07:47 am
Welcome to the forum. Unplug your wiring connector to the fan and direct wire it to the fan for a couple of seconds to test it. If it runs, the problem is a fuse, relay or wiring. If it doesn't run, you need to replace the fan.
VsandFords likes this.
Old 14 Jun 2017, 06:18 pm
The radiator fans are notorious for burning out at least two of the "brushes" in the fan motor. Very little problems with the relays. If you look at the picture of the interior of the fan motor, you'll see the 4 "brushes" (rectangle blocks) that run the 2 fan speeds. Two of them you can see are very short and don't reach the center armature to give power for the fan to spin.
A new fan with lifetime warranty runs about $100 at most auto stores. If you have any skills yourself, it takes about 1 1/2 hours to replace the entire fan and housing. Here's a write-up I did for a 2001 PT on replacing the radiator fan.
Removing the fan and housing 01-05 PT
Overflow tank wont drain back into the radiator Epicbeans Tech & Performance Forum 5 02 May 2013 08:31 am
2001 PT Cruiser Radiator FAN WONT WORK AutoServWorks01 Tech & Performance Forum 12 20 Jul 2012 09:21 pm
who says na ptz cant spin? brightlight07 Tech & Performance Forum 26 24 Oct 2008 10:29 am
To spin or not to Spin? PT Lilly General PT Cruiser Discussions 26 14 Jun 2005 05:35 pm
