oil light on and off...even after oil change
Like Tree9Likes
  • 2 Post By VsandFords
  • 2 Post By bea81
  • 3 Post By NitroPT
  • 2 Post By TheDarkAvengerX
Old 28 Jun 2017, 05:47 am
Default Pt shut off while driving!
Hi all,
Looking for help.My oil light comes on with a *ding*, after the car warms up, I start to slow down or come to a stop the oil light comes on at low engine speeds and then shuts off. It will go off after a few seconds and I can drive again. Once I accelerate, it stops until I begin slowing down for the next stop. Ita not happen very often.I had the oil changed... no leaks, nothing unusual. Oil is fresh and full. No overheating or other symptoms.Its Chrysler Pt Cruiser 2.0 2001 petrol. Milleage 144.000 km. Any suggestions? Thanks!!!
Old 28 Jun 2017, 06:13 am
VsandFords's Avatar
Default Re: oil light on and off...even after oil change
Welcome to the forum from Texas.
Please go to the new member section and start a thread telling us about you and your Cruiser. I'm guessing you are in Europe because of the 2.0 petrol engine.
You didn't mention how many kilometers you Cruiser has. The problem could be a bad oil pressure switch. If it has a lot of kilometers, the oil pressure could be low. It would be a good idea to attach a manual gauge to see the actual pressure.
NitroPT and bea81 like this.
Old 28 Jun 2017, 06:24 am
ok thanks 144.000 km
rckstein and VsandFords like this.
Old 28 Jun 2017, 07:35 am
so it might be the faulty oil sensor but no error codes just checked?
Old 28 Jun 2017, 08:42 am
Clean the connector and the surrounding area. Remove and clean the oil pressure sensor and re-install
Old 28 Jun 2017, 10:23 am
TheDarkAvengerX's Avatar
Send a message via Yahoo to TheDarkAvengerX Send a message via Skype™ to TheDarkAvengerX
You and I are pretty much are having the same problem. My PT has been doing it as well. People first suggested cleaning the throttle body. Which I have but no luck. I have a sensor coming in the mail tomorrow and I'll replace it then or I might wait till the weekend.
2004 PT Cruiser "Starr Edition" 113k miles
2016 Mazda 3 34k miles
Old 28 Jun 2017, 10:50 am
same thing happened to me 6 months ago but it stopped itself but today it started again. I'm really hopeless no error codes etc....also the ABS warning light came on today I get my car tested using car diagnostics this morning wheel speed sensor failed.
let me know if that was the oil sensor please.thanks
Old 28 Jun 2017, 12:29 pm
I did received a code for the oil sensor. No check engine light, but every once in a while when I start it, the oil light comes on. I'll let you know what the results are when I replace it.
Old 30 Jun 2017, 09:28 am
Alright bea, I replaced mine, you can read more about it here.
Change Check Engine light jonesy74 Interior Accessories Forum 6 30 Oct 2016 04:06 pm
oil light on and off...even after oil change mattmmille General PT Cruiser Discussions 12 12 Mar 2009 06:14 pm
fog light bulb change?? careyk General PT Cruiser Discussions 1 12 Feb 2009 07:26 am
how does a newbie change a light bulb? neudorfshots General PT Cruiser Discussions 0 30 Jul 2007 01:09 pm
Interior light color change??? yobiebs Exterior & Interior Styling 3 01 Jul 2003 12:10 am
