Water leak and over-heating!
Like Tree2Likes
  • 1 Post By soyomb
  • 1 Post By ptcruisersteve
Old 28 Jun 2017, 12:47 pm
Default Over-heating and possible water leak!
I have 1 2003 pt cuiser with 140000 miles. When I got the car a belt would squeal sometimes when I started it for about 20 seconds. It would happen more often when I would start the car with the ac one. Then about a month ago my ignition coil went out driving on the highway. I got it replaced and less than a week later the car started to over-heat. Found out the thermostat went bad so I replaced that. After about another week it began to over-heat again and I found that it was not retaining all the water. I would fill up the radiator, drive it for about ten miles and would be able to add more water. I have been putting water in before each time I drive the car. When I turn the car off after driving I hear the overflow tank boiling. Also, when the over-heating started after changing thermostat the a/c stopped blowing cold air. I do not know if this is all related but I wanted to give all the information to better be assisted. Any recommendations or advice would be greatly appreciated.
Thank you.
Old 28 Jun 2017, 01:17 pm
Default Re: Water leak and over-heating!
Welcome to the forum
While we are a forum that can help anyone that joins how about at least taking a little time to start a "how do you do thread" before uses our experience to help you!!??
WELCOME and Forum Rules
^^^^^^We encourage all new members to say hello and introduce yourself to the rest of the community by starting a post in the Welcome New PT Owners thread at the top half of the forum.
I might also add try to looking up and read a dozen or so threads that can give suggestion to help you solve ALL the problem you are having with your PT Cruiser.
If it has EVER happened to a PT Cruiser there is several threads on it and hundreds of responses...
Old 28 Jun 2017, 01:18 pm
Sounds like your radiator fan isn't working the way it should. It is also the fan that should run every time the ac is turned on. Check to make sure that is happening first.
johnlast88 likes this.
2016 Kia Soul Plus Black
Old 28 Jun 2017, 01:35 pm
Does it overheat at high speeds or at low speeds or both?
Have you done a engine coolant pressure test to ensure your engine coolant system is sealed and holding the proper PSI?
Old 28 Jun 2017, 03:44 pm
I will check the fan this evening.
The speed I drive hasn't really made a difference, it heats up while driving on highway or in traffic.
I have not done a pressure test. Is it a very simple procedure?
Tags
ac not cold, over-heating, water leak
Got A Water Leak! bados General PT Cruiser Discussions 16 10 Apr 2017 08:05 am
Pt, jerking and water leak ProperTricky Tech & Performance Forum 20 22 May 2016 04:53 pm
Water Leak on Turbo chuzz General Turbo Discussions 10 18 Sep 2015 01:46 pm
Water leak Under turbo 03turbo Tech & Performance Forum 14 11 Feb 2013 09:24 pm
Water leak! PattiV General PT Cruiser Discussions 2 21 Jun 2009 02:24 pm
