alternator?
Like Tree5Likes
Old 01 Jul 2017, 11:02 pm
turbomax's Avatar
Send a message via AIM to turbomax
Default alternator?
has anyone ever swapped out the alternator to say a GM one wire to bypass having the stupid ecu controlling it?
turbo lag is a courteous head-start!
natural aspiration is never ending turbo lag
Old 02 Jul 2017, 04:37 am
_PTGT03's Avatar
Default Re: alternator?
what is your complaint about the existing system and your intentional desired results
Old 02 Jul 2017, 10:07 am
turbomax's Avatar
i just dont like the ecu controlling something that can be self controlled, as it seems to be a somewhat of a common problem that the ecu fails in the department requiring a replacement ecu, PLUS the stock alternator is rather pricey imo.
Old 02 Jul 2017, 12:18 pm
_PTGT03's Avatar
this is the wrong car for you. mercedes benz and chrysler both designed and engineered the electrical system on this car. in my opinion, it's a quality grade above most domestic vehicles of the 90s.
a large variety ECUs have problems over time, no manufacturer is immune.
this is a solution to a non-existing problem.
domestic components are NOT pricey. try pricing out an AUDI or Mercedes benz alternator. then you can realize by comparison these are very low cost maintenance vehicles.
Old 02 Jul 2017, 12:38 pm
Not sure what if any real advantage to doing this would be? Maybe even more challenges and problems? There are far better options to upgrading the PT's generator but unless they are for a specific purpose..like I said??
Old 02 Jul 2017, 02:33 pm
rob302's Avatar
at 276k my car was still on the original computer. i unhooked the battery and let the car run off the alternator. i unhooked the battery while the car was running. i even took it out running and stuck my battery in another vehicle to get a friend off the highway at 2am. i pretty much did everything they tell you not to do and i never had an issue. you're worrying for no reason.
you could do this i suppose:
EXTERNAL voltage regulator repair?
or just stick an alternator on there and wire it how you please. i rewired my ford and connected the voltage sensing wire to the starter solenoid where the key on power is distributed throughout the vehicle. i made the bracket to relocate it in only a couple hours. alternators are simple. if it makes your day, then go for it. seems like a waste of time to me though
Old 02 Jul 2017, 03:43 pm
turbomax's Avatar
each to his/her own i suppose....
Old 03 Jul 2017, 08:52 pm
turbomax's Avatar
i just have to LOL at this ridiculous comment...seriously.
grandads_shed likes this.
Old 03 Jul 2017, 09:32 pm
VsandFords's Avatar
Well, it looks like no one has tried this. Tag, you're it. Try it and let us know how it works out!
turbomax likes this.
Old 03 Jul 2017, 09:40 pm
turbomax's Avatar
that's the plan...even IF this is the wrong car for me!
Alternator mazdaspeed23 Classifieds: For Sale/Trade 1 15 Sep 2013 02:17 pm
03 gt with bad alternator jacarc1 General Turbo Discussions 5 31 Mar 2010 03:47 pm
H/O Alternator jonnbr Sound and Security Forum 0 18 Nov 2009 02:08 am
alternator hillbilly678 Tech & Performance Forum 4 05 Nov 2009 02:51 pm
Alternator Mark Tech & Performance Forum 0 13 Feb 2002 05:46 pm
