Transmission Mount Bolt Wont Tighten?
Old 02 Jul 2017, 10:11 pm
Flash619's Avatar
Default Transmission Mount Bolt Wont Tighten?
Alrighty, so I've gone though all the trouble of pulling a dead trans, shoving in a new trans (which took four hours to get aligned and bolted to the engine), then finally got the transmission mount holes to align. The holes for the transmission mount didn't want to line up, and it seemed as if the transmission was too far towards the driver side which was impossible because it was tight against the engine (and bolted to the engine).
I have 1 out of the 2 bolts in and torqued (not sure what the spec is but it's torqued to 80lb, probably way overkill).
The second of the 2 bolts I cannot get to torque down. It feels like there is tension, but it never gets tighter and I feel either the bolt, or the threads are likely messed up. This same bolt I had to shorten slightly because its first two threads rolled over on me initially and it wouldn't catch, so I cut it off and beveled a new end on it.
I'm not sure if I should be concerned since I can't pull the bolt out and it is tight. There is another bolt that is torqued and holding, but I'm not sure how important both bolts actually are. Is the second bolt just in case the first one breaks?
I'm not seeing much info on the bolts themselves for this mount online (tons of stuff for dog bone struts etc...).
Any ideas on if I should worry and pull it to check, or if I should just leave it and pretend it's fine?
Old 03 Jul 2017, 08:06 am
Default Re: Transmission Mount Bolt Wont Tighten?
Sounds to me like you cut the bolt off too short. And I NEVER torque one bolt in on anything until I have all the bolts in and snug. Maybe try loosening the bolt you torqued down and see if the other one will catch. If not, you may need to go buy a longer bolt.
Old 03 Jul 2017, 10:44 am
Flash619's Avatar
They were both very snug before I torqued them.
Old 03 Jul 2017, 11:26 am
Okay, I guess it's just how I read it. I guess the threads are stripped and you need a longer bolt. Is it an open hole where you could put a nut and lock washer on the back side with a longer bolt?
Old 03 Jul 2017, 11:28 am
Azrak's Avatar
Just a guess but could the bolt be going into a welded to frame/body nut that has broke loose?
Old 03 Jul 2017, 11:32 am
Flash619's Avatar
These bolts go directly down into the transmissions mount bracket. This bracket sits directly onto the transmission, so there is no way to get under it.
Furthermore if the hole is malformed the entire mount bracket would need to be replaced so I'm hoping that's not the case.
I'm not sure if one bolt is enough to hold up the transmission, and I would really like to know the proper torque spec for these. :/
Here's an exploded view.
Bolt 1 is the bolt that is not torquing.
Old 03 Jul 2017, 11:34 am
I don't think one bolt will be enough, but I'm not a mechanic. Maybe a helicoil?
Old 03 Jul 2017, 11:37 am
Flash619's Avatar
You may not have seen it, I posted an exploded view.
Old 03 Jul 2017, 11:43 am
No, I missed that. Sorry, man. I can't help you with this as I don't have a service manual. IIRC, they're 85 or 87 ft. lbs. Maybe NitroPT will see this and can tell you.
Old 03 Jul 2017, 12:27 pm
rob302's Avatar
I would just drive it. If the previous owner did it i bet you'd never know
motor mount, transmission mount and torque struts tourhar Tech & Performance Forum 17 23 Oct 2016 11:41 am
Motor Mount Bolt ? red98gt Tech & Performance Forum 7 10 Oct 2016 09:31 am
mid- motor mount bolt willy13 General Turbo Discussions 15 30 Mar 2016 11:32 pm
Broken motor mount bolt madeupofwires General PT Cruiser Discussions 1 24 Jun 2014 03:58 pm
WTB - 06506379AA - Engine mount bolt (frame though bolt) wheelgarage Classifieds: Want To Buy 5 04 Dec 2011 10:31 pm
