2006 PT
Like Tree5Likes
  • 1 Post By ptcruisersteve
  • 1 Post By CREWZIN
  • 3 Post By ConfusedPTowner
Old 07 Jul 2017, 06:07 pm
Default 2006 PT
Here are the issues: It all started with the rpms dropping to around 500 and the car acting like it was going to stall, then the rpms would go up to around 800 while sitting at a red light. So, I put the engine in neutral and reved it. Then, a strange noise came from or around the starter and white smoke that smells electrical came from the same area when the rpms reach approximately 1800.
So, thinking something was wrong with the starter, I replaced it. I then drove the car approximately five miles down the road and everything ran fine. I turned around and began the trip back when the same issues happened again twice. The first was at a red light about 2 miles from home. This time though, I noticed that the AC got warm when it happened. The second time was at the red light 200 yards from home. This time the AC got warm as well and the temp. gauge went high enough for the idiot light to come on.
When I got it back in the driveway, there was no water leak and I did not notice the engine any hotter than normal. I did not think to check the top hose to see if it was hot.
Please, any ideas would be appreciated.
Old 07 Jul 2017, 06:32 pm
Wolfman01's Avatar
Default Re: 2006 PT
AC compressor seizing, AC compressor clutch failure, or temperature sensor failure for the freon causing it to load up and seize.
2018 Jeep Compass Trailhawk
2015 Chevy Colorado Z71 Trail Boss (22k)
2004 Saturn ION Redline (9k)
Old 07 Jul 2017, 06:41 pm
Default Re: 2006 PT
I would check to see if the radiator fan is working properly. See if the radiator fan plug or wiring going to the plug is overheating and burning up causing the white smoke. If your radiator fan is not working properly it can affect the rpm's and the engine temperature. Has the radiator fan been replaced or is it the original radiator fan?
rsrocket1 likes this.
Old 07 Jul 2017, 06:57 pm
Default Re: 2006 PT
Some report white smoke and it's caused by the fan not cooling down the compressor whereas the compressor lets off R134a into the atmosphere to get rid of built up pressure.
Pressure relief valve blew open! - Automotive Air Conditioning Information Forum
Old 11 Jul 2017, 07:15 pm
Default Re: 2006 PT
Thank you all for your suggestions. It was a bad fan. Forty-five minutes and $140 and the car is running good. The only thing is that the AC is not very cold anymore. I'll charge it up in a couple of days. Again, Thanks.
Tags
air condition, loss of power
2006 and Up NA Air Box soonercruiser PT Pass It On 8 15 Jan 2017 11:25 pm
AIR HOG for PT 2006 kctobyjoe Tech & Performance Forum 5 10 Dec 2013 08:14 pm
2006 pt need help? hightimer Tech & Performance Forum 4 22 Oct 2010 10:55 am
2006 PT GT KC2IFR General Turbo Discussions 1 05 Sep 2009 09:03 pm
2006 CHRYSLER PT CRUISER AUTOMATIC FACTORY WARRANTY, VERY CLEAN CAR (2006 CHRYSLER PT skylight craigslist 0 15 Jul 2007 01:10 am
