Failed AC recharge
Old 09 Jul 2017, 05:06 pm
Default Failed AC recharge
So I tried to recharge the AC on my daughter's '02 and had no success. First off, the lower port had no cap. When I started squeezing the trigger it flashed to red, then settled back. It took very little time for the gauge to read filled, unfortunately the air is still blowing hot. Any thoughts?
Old 09 Jul 2017, 05:15 pm
VsandFords's Avatar
Default Re: Failed AC recharge
Is your hi speed working on your fan? Did you try jumping the low pressure switch? Check any relays or fuses?
Old 09 Jul 2017, 05:26 pm
I did replace the fuses, the fan was working. I did not check relays - I'll look into that. Thank you.
Old 09 Jul 2017, 05:27 pm
Is the A/C still hot at highway speeds?
Old 09 Jul 2017, 05:40 pm
So it is better at higher speeds, but not actually cold.
Old 09 Jul 2017, 08:03 pm
So I would say it is cooler, but certainly not cold. We didn't have a chance to hit high way speed, but did run 50 for a bit.
Old 10 Jul 2017, 09:10 am
How can a man determine if his high speed radiator fan is working ?
Here , we may need a schematic .. Haynes ?
The high speed ''air rush'' MAY partially make up for a no-go high speed fan .. or , it may not .. depending .
Old 10 Jul 2017, 09:38 am
Sorry?
Old 10 Jul 2017, 11:19 am
Start the car and with it idling, turn on the a/c. The low speed fan should come on pretty quickly. Let it sit and idle for a few minutes. If it's working properly, as the engine temp comes up, the high speed fan will turn on. You'll notice the difference by the sound of it. It revs much higher than the low speed fan.
Old 10 Jul 2017, 12:14 pm
cruserdad1976's Avatar
well if there is air in the system it will only take a small amount of Freon you really need to suck the system down and see if it holds then recharge from there but you would need a set of gauges and a vacuum pump to do that
Product to recharge A/C Gkon General PT Cruiser Discussions 30 30 Jun 2017 02:32 pm
2001 PT Cruiser A/C Recharge lmarkie74 Tech & Performance Forum 0 12 Jul 2015 11:33 am
AC recharge port for 2005 classic briancpearce Tech & Performance Forum 23 08 Apr 2014 12:41 am
03 vs 04 AC recharge - the definitive word? mmhendrie Tech & Performance Forum 11 17 Jun 2012 08:56 am
Recharge AC? jmack General PT Cruiser Discussions 2 18 Apr 2005 06:58 pm
