Misfire and stalling issue
Like Tree6Likes
Old 15 Jul 2017, 06:12 pm
Default Misfire and stalling issue
My 04 turbo just started stalling today at red lights. The check engine light is on and blinks sometimes. I got p0201, 202, 203, 204, p0032, p0038. It would buck randomly and there is no power. I changed the spark plugs already and cleaned the air intake. Any idea where I should look based on the codes?
Old 15 Jul 2017, 06:44 pm
Default Re: Misfire and stalling issue
P0032 and P0038 are both upstream and downstream O2 sensor heater voltages high. Usually high sensor voltage readings are caused by an open or poor ground. Without the ground many components will read a higher signal voltage than they should and set the 'voltage high' fault code.
The P0201-P0204 faults are fuel injector electrical faults on all 4 cylinders.
All these codes may all be related to a wiring harness problem that has these components in common. I would start with a thorough visual inspection of the under hood wiring harness for corrosion, rub through, breaks, burns, chewing and any other possible wiring harness damage.
Check the ground wires going to the drivers side inside fender. The group of wires get corroded and lose contact.
If everything else checks out good you might need to check the ECU.
Old 15 Jul 2017, 08:27 pm
_PTGT03's Avatar
I'm very certain it's your wiring harness. The fuel injector driver circuit wires and ignition coil wires are prone to internally failing (high resistance) intermittently or outright - from age and heating from the engine valve cover. I'm certain that if you temporarily bypass and jumper to the ECU the problem will go away determining the cause of the issue.
That was the case with my intermittent misfire and loss of power.
Old 16 Jul 2017, 11:07 am
Thanks for the help. I'm not sure where those components are on mine. Is there a guide somewhere for the pt cruiser turbo?
Handy_Cruiser likes this.
Old 16 Jul 2017, 11:20 am
Handy_Cruiser's Avatar
I've uploaded the service manual for the 1st Gen PT's including your 2004 turbo model. You can download it at this link:
https://drive.google.com/file/d/0B9C...ew?usp=sharing
rockandroller likes this.
Old 21 Jul 2017, 06:41 am
I took it in to a trusted mechanic and he tested the wiring harness and said it checked out but did see green corrosion in it. He cleaned it but it didn't fix the issue. He said it looked like both O2 sensors were new. But they may not be OEM and could cause problems? I'm thinking it's the ECM after reading other people's experiences.
Old 21 Jul 2017, 02:08 pm
Ground wires on left fender need to be removed from the single eyelet, cut back about an inch to good copper and stripped.
I soldered the smaller wires to new eyelets two wires each eyelet.
Cheap fix if it works. If it doesn't you still didn't waste much $.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 22 Jul 2017, 03:26 pm
_PTGT03's Avatar
the problem with that is you have an intermittent issue, and just testing the wiring harness will get no where
Old 23 Jul 2017, 01:34 pm
When you said "temporarily bypass and jumper to the ECU" I have no idea how to do that. Or what an "and jumper" is. But I would love to learn
Old 23 Jul 2017, 09:46 pm
_PTGT03's Avatar
i think at this point the problem is over your skill level. it took me many years of working on cars before i could master electronic troubleshooting and that's why i charge $100/hr . see if you can get an auto electrician where you are
03 misfire issue gracie Turbo Performance 0 21 May 2017 03:25 pm
Stalling while turning at low rpm issue. NickDonero General PT Cruiser Discussions 8 19 Apr 2017 12:34 am
stalling issue ruby3068 Tech & Performance Forum 8 16 Oct 2014 08:10 am
Isolating cylinder misfire issue Pricejh Tech & Performance Forum 8 27 Mar 2014 06:54 pm
Misfire issue SCBluePT General PT Cruiser Discussions 9 03 Dec 2010 03:04 am
