2007 Cruiser wont start when its hot outside
  • 1 Post By ptcruisersteve
Old 27 Jul 2017, 07:14 am
Exclamation 2007 Cruiser wont start when its hot outside
Hi everyone, i have a real brain teaser here. I have a 2007 2.4L non turbo Cruiser. When its hot outside, i will not crank at all. everything powers up as normal, but there is nothing going on under the hood. The battery and Starter have tested good. As i said, it only happens when its been sitting in the sun all day (usually at work). If it rains, or it sits overnight in my carport, it starts lie there is no issue. Once its been sitting in the sun, it can take 10-15 minutes and then it'll crank. and once it cranks that first time, it cranks every time UNTIL the following day it sits in the sun at work! Weirdest crap ever. Ive seen a few people ask about this, with no real answer. Thanks for any help you can throw my way!
Old 27 Jul 2017, 09:42 am
Default Re: 2007 Cruiser wont start when its hot outside
First I would suggest checking a group of ground wires going to the inside drivers side fender under the hood.. The wire contacts get corroded inside and it can look good on the outside. Post if this helps or not.
Also does the red little security light stay on when it happens?
Gkon likes this.
Old 27 Jul 2017, 11:03 am
LionPT's Avatar
This could still be a battery problem...the heat from hitting the hood all day can make it hotter. Try parking in the shade if you can or put a cover on the car.
You can test this by putting a tarp or 2 over the hood & see if it works.
Old 27 Jul 2017, 11:55 am
Fk5 Fk5 is offline
Probably not the case with a modern car and in-tank fuel pump, but I have had similar problems with vapor lock. The fuel boils and the lines can't pressurize.
That can trigger the ASD in some cars - my '82 efi Imperial was notorious for this - it had an aftermarket out of tank pump and it was brutal to start sometimes.
2003 GT 5 speed
162,000 miles
Old 27 Jul 2017, 01:44 pm
Sounds like some sort of thermal expansion problem. Maybe the ignition switch or TIPM. I'd put a windshield shade in it and make sure it shades the steering column, in order to test the ignition switch.
Old 27 Jul 2017, 06:02 pm
I was thinking possibly the ignition switch also. I found I get zero volts to the com wire on the starter. But the next time I turn the key, it may crank or partially crank, then I lose voltage again
Old 27 Jul 2017, 06:59 pm
Are you planning to answer the questions in the previous posts?
Tags
heat, no start, tired of pt lol
my pt cruiser wont start at first Roy2k General PT Cruiser Discussions 6 25 Jun 2013 09:55 pm
2007 diesel cruiser turns over but wont start after front end shunt guitarman Tech & Performance Forum 0 07 Jan 2013 06:37 am
2007 PT Cruiser Overheated now wont start!! kbryant Tech & Performance Forum 15 25 May 2012 03:55 pm
cruiser wont start earnhardt724 Tech & Performance Forum 3 21 Jan 2012 10:33 pm
07 Cruiser Wont Start! 07fastptloser General PT Cruiser Discussions 1 15 Feb 2011 06:52 am
