A/C compressor causing engine stumble
Like Tree7Likes
Old 27 Jul 2017, 06:28 pm
Default A/C compressor causing engine stumble
My 2005 PT (non turbo) a/c would be nice and cold and then the engine would stumble - causing the a/c to go warm. Today I noticed that when the a/c would go warm and engine stumble, I reved engine and got belt noise and a bit of smoke.
I assume the a/c compressor is locking up.
I hear no bearing noise. It happens after car has been sitting awhile.
- what would cause the compressor to act like this?
Old 27 Jul 2017, 07:04 pm
Default Re: A/C compressor causing engine stumble
Is your radiator fan working properly?
Does it also happen at highway speeds or only city speeds?
Old 27 Jul 2017, 07:40 pm
Mainly happens at idle.
Should the fan have 2 speeds? How should I check?
Old 27 Jul 2017, 07:55 pm
With the engine cold, start the engine, turn the A/C on and see if the radiator fan comes on almost immediately.
Old 27 Jul 2017, 08:51 pm
Cold engine start / turn on A/C
- no fan movement
What do I check next?
Old 27 Jul 2017, 09:03 pm
Seems like good advice here:
AC Only Blows Cold While Moving....
Old 27 Jul 2017, 10:43 pm
First thing you need to do is unplug the radiator fan and manually apply 12 volts to both speeds..
If fan works on both speeds check the fan plug for bad contacts. If that is okay check the fan relays.
Let us know what you find out.
Gkon likes this.
Old 28 Jul 2017, 08:44 pm
I tested the fan and it did not have both speeds working. Although I replaced it 5 years ago, I forgot it was covered under warranty. Exchanged for free - praise the Good Lord! New fan and now I have A/C again. Thanks to all for your help.
So the symptom was engine stumble with compressor locking up and warm air.
Installed new fan, now the A/C works as it should.
Old 28 Jul 2017, 08:46 pm
I had let out a bit of gas in testing. I used an A/C can from Advanced Auto with a gage. Here is a video.
https://youtu.be/9rjDVucRI2Q
Does the pressure look right? The cycle time was a bit longer after a 10 minute drive.
Old 28 Jul 2017, 08:59 pm
rckstein's Avatar
This is bound to start a debate, but not if any other member asks the same question, but what brand of fan was it?
Tags
a/c compressor
Really? A/C Compressor Stumble Is Normal? NewPTCruiserInPA Tech & Performance Forum 172 12 Mar 2017 05:31 pm
AC Causing Drop In RPM At Idle. techno2 Tech & Performance Forum 3 14 Jun 2015 12:00 pm
AC compressor/engine idle speed mdkinney Tech & Performance Forum 1 04 Jun 2015 07:45 pm
What's causing this noise? ptcru1s3r Wheels, Tires, Suspension 4 03 Apr 2012 09:01 am
A/C causing car to jerk.?? clark6 General PT Cruiser Discussions 18 12 Sep 2011 04:05 pm
