Ignition locking
Like Tree4Likes
  • 1 Post By ptcruisersteve
  • 2 Post By rob302
  • 1 Post By bluesriff
Old 28 Jul 2017, 11:31 am
Default Ignition locking
So my daughter's ignition is locking on her '02 cruiser. I found a quick fix online where you tap the key with a hammer. It worked, but I would prefer to actually FIX it so we are not driving around with a hammer. is there a way to fix the current ignition or should I plan on replacing it? The steering wheel does turn, so from what I quickly read it seems to be the ignition. Thank you!
Old 28 Jul 2017, 11:57 am
Default Re: Ignition locking
There's a piece on the end that breaks off sometimes. You may want to replace the lock cylinder and key.
Old 28 Jul 2017, 12:05 pm
Thank you - thought that would be the case but wanted to run it by you guys. Again, thanks!
Old 28 Jul 2017, 05:24 pm
No problem. If you do a search here, I'm sure you can find descriptions and MAYBE a photo or two. Seems like a lot of members here used photobucket for their photos and now photobucket wants about $400 a year for a membership. They deleted everyones photos. I guess to show they were serious.
Old 28 Jul 2017, 05:33 pm
This is just an example of a ignition switch and you can see the plastic piece at the end of it that sometimes break.
Old 28 Jul 2017, 05:44 pm
rob302's Avatar
if the hammer trick is working, it's definitely the lock cylinder itself.
don't bend the key, but.... hitting it HARDER usually fixes it permanently
Old 30 May 2018, 07:22 pm
Yep,,,Hammer did the Track! Thanks!
rob302 likes this.
Old 31 May 2018, 03:18 pm
IMO, the hammer trick is temporary, as is graphite oil lubrication. DO plan on renewing the lock cylinder and tumblers ..I have seen these for $18 on up - depending on how much you are willing to overspend .
Best is the annual lubrication, which very few of us do !
C/locking. Stoddys General PT Cruiser Discussions 14 03 Feb 2015 12:29 am
Locking up a pistol in a PT? reh8388 Interior Accessories Forum 28 20 Jul 2014 05:11 am
Locking Gas Cap wayne2001ptcruiser Classifieds: Want To Buy 17 06 Apr 2014 06:59 pm
Locking PT Street_Rod_Guy General PT Cruiser Discussions 20 04 Jan 2011 04:53 pm
Locking Gas Cap technobear General PT Cruiser Discussions 3 22 Aug 2005 12:04 pm
