Clutch Pedal Intermittently Goes to the Floor
Old 06 Aug 2017, 04:15 am
Default Clutch Pedal Intermittently Goes to the Floor
My 2003 pt cruiser clutch started slipping a bit last year and the pedal recently started going all the way to floor. If I'm not going over the mountain and on a flat road the slipping is barley noticeable. I know there is another good year of clutch left, but I can't figure out why the clutch pedal becomes so loose.
Anyone have an idea or a fix? (short of a new clutch, master and slave)
I will try bleeding the system first. Where is the bleeding tip located?
Thanks everyone!
Scott
Old 06 Aug 2017, 08:48 am
rob302's Avatar
Default Re: Clutch Pedal Intermittently Goes to the Floor
You'll need to look at it. There was no bleeder in my 2002.
If your 03 is a GT, try this: 03 Turbo clutch bleeding
When I asked for my 2002, I got this: bleed clutch?
Old 11 Aug 2017, 04:50 am
Thanks brother! I pumped the heck out of the pedal and now the clutch won't disengage at all
I found the manual on the forum and believe I will just need to replace the master and slave. Doesn't look like that big of a job. Just hate to spend the $175 to buy one.
If that doesn't work, I guess it's a new clutch next.
Old 11 Aug 2017, 06:45 am
Rockauto has the clutch master and slave kit cheaper than that. 2003 CHRYSLER PT CRUISER 2.4L L4 Clutch Master and Slave Cylinder Assembly | RockAuto
GT CLutch pedal adjustment VNT General PT Cruiser Discussions 5 19 Nov 2016 04:07 am
Clutch pedal switch Batfalcon Europe PT Forum 12 07 Mar 2013 02:53 pm
CLUTCH PEDAL PROBLEM pipjes Tech & Performance Forum 3 05 Dec 2012 05:24 am
PT clutch pedal ass'y 1972cudaguy Classifieds: For Sale/Trade 2 25 Mar 2012 05:12 pm
???Clutch pedal adjustment??? Ctown General PT Cruiser Discussions 5 28 Feb 2005 09:08 pm
