Headlight problem
Like Tree10Likes
Old 10 Aug 2017, 02:27 pm
Default Headlight problem
First off, I have searched the forum, and have come up empty on answers. I have a 2005 with the passenger side low beam out. I did the obvious and changed the headlight bulb, but no change. I broke out the testers both multi-meter and circuit (which will tell what is power and what is ground). Tested with the circuit tester showed power side and ground side had continuity. Tested with the multi-meter and showed 11.78 volts at the pigtail. Spliced in a new pigtail just for giggles, and still no change. At this point I have no idea why the headlight will not come on. Any suggestions would be greatly appreciated.
Old 10 Aug 2017, 02:36 pm
Default Re: Headlight problem
Have you checked the headlight socket to see if it working properly? Check to make sure the contacts are clean.
Old 10 Aug 2017, 02:44 pm
I might be misunderstanding, but if you are referring to the socket that the bulb plugs into then yes, and no results. If you are referring to where the bulb goes into the headlight housing, then no.
Old 10 Aug 2017, 02:52 pm
Did you check the voltage at the socket with a voltmeter with the low beam on?
You might have a bad ground wire or a broken wire if your headlight bulb low beam is good.
Old 10 Aug 2017, 02:59 pm
Yes sir. 11.78 volts with the low beam on, and a little over 13 volts with the car running.
Old 10 Aug 2017, 03:25 pm
Are you sure the new light bulb is good?
When the high beam is on is the low beam also working?
Old 10 Aug 2017, 04:14 pm
Just double checked it. With the high beams on, the low beam is still out. And the new bulb tests good.
Old 10 Aug 2017, 04:20 pm
With the high beam on, is the other low beam working on the other headlight?
Old 10 Aug 2017, 04:24 pm
Yes sir, and all other bulbs are functional as well. This really has me baffled.
Old 10 Aug 2017, 04:34 pm
I would need to get back to you later today when I have more time to look at the wire diagram.
If you time you can look this up on the 01-04 manual below.
http://www.mediafire.com/file/lmvdwn2nywm/01-04CPTC.pdf
headlight problem 1AZPT Tech & Performance Forum 2 20 Aug 2014 11:20 pm
Headlight Problem PTColossus General PT Cruiser Discussions 5 22 Nov 2011 11:25 pm
help,headlight problem :( drsarman Tech & Performance Forum 3 13 Sep 2010 07:21 pm
Headlight Problem Madturtle Tech & Performance Forum 2 04 May 2009 08:05 pm
Headlight Problem jmack General PT Cruiser Discussions 21 23 Nov 2007 05:58 pm
