Knocking in front
Like Tree5Likes
Old 11 Aug 2017, 08:23 am
Vengence's Avatar
Default Knocking in front
Hey everyone,
Seems like issue after issue with this....
But most are gone now....
Currently, After replacing the Front Struts, CV Joints, CV Boots, Sway Bars/links, there is a bad knocking noise whenever I go over bumps in the road. I have checked the Ball Joints and Control Arms, they look alright and haven't noticed anything knocking about, Had the car on the lift and wiggled the wheels, nothing.... the Struts and CV joints have been replaced/warrantied 3 times now. The knocking seems to be coming from the struts but I don't see how that is possible? Any thoughts?
Next option is to take it to the Dealer if I can't find anything.
2008 PT Cruiser LX Inferno Red
Old 11 Aug 2017, 08:46 am
Default Re: Knocking in front
The struts..were they a complete assembly or did you reuse your springs. To check..There is a proper installation that must be followed or it may be possible the springs may be making noises? I wonder why the shop would simply warranty parts them so many times without verifying they were defective....hmmm??? No need to answer just commenting out loud.
The down side is if you cant find it with having the PT up in the air on a lift than a forum is not going to be helpful except to go down the list of every potential part in the front suspension?
I would say on a new day with a fresh start get it back up on the rack and reinspect everything again? You WILL find the cause of the noise!
Old 11 Aug 2017, 09:14 am
rob302's Avatar
i would temporarily remove one of the swaybar end links and see if the noise persists
Old 11 Aug 2017, 09:26 am
VsandFords's Avatar
I would recheck the struts and strut mounts like NitroPT suggested. Especially if you didn't replace the complete assembly.
Old 11 Aug 2017, 09:51 am
The bushings on the sway bar mounting brackets. If you can move that bar any at all in that bushing. That's your moise. Like an earlier post said. If you disconnect the end links and noise stops. That's the proof that the mounting bushings are bad.
Old 11 Aug 2017, 09:01 pm
Vengence's Avatar
NitroPT- The struts were a complete assembly. It's going back on a lift on Tuesday for new Rims, Tirres and TPM's that were bought about a month ago and will re-evaluate every part of the suspension....
Rob302- Isn't the sway bar needed to drive the car on the road? Or do you mean just remove it on the lift and see if the problem persists? I am assuming the latter of the 2. If so, When its on a lift, we cannot recreate the knocking noise no matter what we do. Well, Technically the only thing we have not done yet on the lift is lift the tire up a bit and just let it drop which I thought about doing but didnt know if that would cause any damage to any part.
VsandFords- this is currently the 3rd pair of struts now but will check the strut mounts. not sure if those were checked.
Busted_PT- will do this and see what happens Tuesday.
Currently the car is sitting in my garage waiting until Tuesday.
Old 12 Aug 2017, 04:04 am
RickinPA's Avatar
Like the earlier posters said, check the sway bar bushings. I had an annoying random thumping on our Neon. I went to replace the sway bar links and removed them both. When I did, the sway bar just flopped (rotated) down in the bushings where it connects to the body. I could take the sway bar and rattle it around in the bushings. "There's your thumping" I thought. It's hard to diagnose bad sway bar bushings when the links are installed. With the links installed, the sway bar is firmly loaded against the bushings and will seem tight.
Old 12 Aug 2017, 07:05 am
You don't need the sway bar in order to drive the car. I removed mine off the GT and didn't really notice much difference at all. I left it off for about a month until I could afford to order the new bushings and end links for it. Don'l let ANYONE tell you otherwise.
NitroPT likes this.
Old 15 Aug 2017, 05:23 pm
Vengence's Avatar
So, just got new rims and tires put on today. I had the tires and rims for about a month now but didnt want to install them with the current issues.
The knocking right now is still there however, not as noticeable as it was before. New rims and tires quieted it down quite a bit. Again, Sway Bar and Links looked good from what they said but didnt have much time today so, we will be looking into it next week.
Also, for those who remember me complaining about Vibration at high speeds.....That is now resolved thanks to new rims and tires. Figured out that all 4 of those previous rims were bent to shit and the tires were cupped and 1 was out of round. Thankfully, all is good now and was told that the knocking is not going to interfere with the wear on my tires.
From what I can tell, CV Shafts/joints, struts, ball joints, and alignment are key to cause wear and none of those seem to be an issue.
Oh well, Take it day by day but all I know and care about right now is that that cursed vibration is FINALLY GONE!
rckstein likes this.
Old 15 Aug 2017, 06:45 pm
Kick the front tire where the noise is coming from, kick it right where the outer tie rod would be, if you can recreate the knocking by just kicking the tire right there by the tie rod it could be the tie rod. That's how I found out what was knocking on my dream cruiser. GL.
Knocking from right front undercarriage cardone General PT Cruiser Discussions 5 31 Oct 2014 08:03 am
Front end knocking when pulling away. Zez Wheels, Tires, Suspension 3 09 Jun 2013 04:18 pm
Knocking sound from front end Lojo61377 Wheels, Tires, Suspension 3 03 Apr 2012 02:59 pm
Front End Knocking and Vibration arnsc Wheels, Tires, Suspension 11 10 Mar 2011 03:34 pm
Knocking in front end. warmonger13 General PT Cruiser Discussions 4 26 Nov 2010 07:07 am
