Water pump brand
Like Tree17Likes
Closed Thread
Old 15 Aug 2017, 08:42 pm
Default Water pump brand
2003 pt non turbo can someone recommend a good brand water pump and which ones to stay away from ? Is gates a good brand ?
Old 15 Aug 2017, 09:03 pm
Default Re: Water pump brand
Water pump any to avoid ?
TURBO VS NON TURBO WATER PUMP AND TIMING BELT KIT
Old 15 Aug 2017, 09:24 pm
None are bad some are better.
I have tried to recommend that a better choice is Airtex AW7167
Old 15 Aug 2017, 11:08 pm
I was looking at the gates water pump at rock auto and it say "A small amount of coolant leaking from the weep hole is normal. Small drips are OK.Longer streams or continuous leaking may indicate a problem" I don't thank a want any leaking on my timing belt. Thanks for the link "ptcruisersteve" I thank I will take your recommendation NitroPT" and go with the AIRTEX
Old 15 Aug 2017, 11:12 pm
is the Airtex AW7167 for turbo ? All I see is AIRTEX AW7156 under non turbo or will the turbo model work with non turbo ?
Old 15 Aug 2017, 11:24 pm
I am planning to use an turbo Airtex water pump on my N/A Pt Cruiser when I change my timing belt.
There are several reasons to look at an Airtex water pump. Improved casting over other brands including OEM, less frictional fluid drag, timken bearing and seal. Proven engineering design to lower the chances of high RPM cavitation and improved water flow volume.
NitroPT likes this.
Old 15 Aug 2017, 11:28 pm
ya the turbo one looks way better so the turbo one is a direct fit for a non turbo ?
Old 16 Aug 2017, 12:01 am
This is what NitroPT posted in another thread. I would wait to have NitroPT answer your question about a specific Airtex water pump. NitroPT has much more information than I do about Airtex water pumps and he currently uses them on his own PT Cruiser.
The Airtex Turbo model water pump I think I did a good job to show in FACT a better choice overall for a NA or Turbo model PT Cruiser based on testing others comparing simple results and recommending to other PT Cruiser forum members and myself and the shop successfully installing several and still running well on various PT Cruisers over the last 5 years. I can't say that about other water pump brands for a PT Cruiser.
I also want to add that in the last couple or few years I have regularly RACED my PT Cruiser 1/4 mile with no heating issues or AIRTEX water pump failures.
Old 16 Aug 2017, 08:41 am
Yes..
Old 16 Aug 2017, 08:51 am
Handy_Cruiser's Avatar
For me, I'm a big fan of the American/Canadian made Gates waterpump. The turbo pump comes with a steel impeller as opposed the to the plastic impeller on the OEM and Chinese made pumps like Airtex. If you get this in the kit with rest of the timing belt components, you also get documentations and a decal to go under the hood showing when the timing belt was changed. The way I see it, if you are going to do all this work yourself, you might as well use high quality parts.
Closed Thread
Water pump woh's normdude General PT Cruiser Discussions 8 06 Nov 2016 09:22 pm
Water pump chobbsy Tech & Performance Forum 8 07 Nov 2013 07:46 am
water pump dingdangdo Tech & Performance Forum 4 20 Jul 2012 05:34 pm
Water Pump rute66pt General PT Cruiser Discussions 4 03 Dec 2009 01:56 pm
water neck for the water pump Boxerjl2 Classifieds: For Sale/Trade 3 31 Jan 2008 02:48 am
