Cooling Fan Turns on at what temperature
Like Tree3Likes
Old 16 Aug 2017, 12:21 am
Default Cooling Fan Turns on at what temperature
Hello all. I like to know if someone can tell me if my concern is normal for the cooling fan. I have my car on and sitting still in park. My A/C is turned off. The cooling fan does not turn on into my temp gauge go up 3 marks (the half way mark). It does not turn off into the temp gauge go down half a mark. When the cooling fan turns on it is running at low speed.
If the A/c turn on then the fan will run at high speed.
Is this normal is something wrong.
Also can you tell me what mark should the temp gauge be at when the fan turns on low speeds sitting in park.
I have attached a photo. The yellow mark is when my low speed turn on and the green dot is where it turns off once it has been on
Old 16 Aug 2017, 01:01 am
Default Re: Cooling Fan Turns on at what temperature
Usually it common for the low speed fan to fail. I would recommend you manually check the radiator fan low speed and see if its working properly or not if you think your engine might be overheating.
Old 16 Aug 2017, 01:33 am
I just replaced the fan with a new one today. I did this because the old fan had a problem. however I notice this problem with the new fan as well. I have check to see if any wires were bad but they all seem to be good.
I have the A/C connected but it needs to be charged. would that create they problem
Old 16 Aug 2017, 06:29 am
LionPT's Avatar
I don't see a problem...from you post & pic, it's working as it should.
03TXPTGT likes this.
Old 16 Aug 2017, 07:09 am
I agree.
Old 16 Aug 2017, 08:21 am
Wolfman01's Avatar
Yep, that looks right on the money. When I'm sitting in traffic mine will creep up to that mid mark before dropping. back to about where you have the low mark indicated. According to my ultragauge, that's about 212 degrees.
2018 Jeep Compass Trailhawk
2015 Chevy Colorado Z71 Trail Boss (22k)
2004 Saturn ION Redline (9k)
Old 16 Aug 2017, 12:29 pm
Azrak's Avatar
I agree with LionPT, myckee and Wolfman01 that when sitting and idling this is exactly how it should be.
As long as you don't start running over a notch or two above the center mark while driving you should have no problems.
2005 Touring Convertible - 2.4L I4 DOHC 16V Turbo Engine - 4-Speed Automatic Transmission.
LT. Almond Pearl Metallic Clear Coat - Black Cloth Top.
Cloth Low-Back Bucket Seats - Dark Slate Gray.
Old 16 Aug 2017, 12:46 pm
I am curious as to why you are asking these questions unless something happened that was not normal?
Old 16 Aug 2017, 12:55 pm
except his picture is WAAAAY TO BIG
jseigle85 in the future you really should keep your pictures much smaller. CREWZIN the forum moderator will be along to edit your picture unless you do it first.
Old 16 Aug 2017, 12:59 pm
hmm a notch or 2 I am not sure I would say that... to bad my pictures are gone you would be very surprised what is going on in the so called middle and slightly a hair above it....
Turns over but won't start fisherman Tech & Performance Forum 30 11 Nov 2016 01:38 am
Installed and new cooling fan and cooling temp sensor & still the fan doesn't kick in rdvarona Southeast PT Forum 18 31 May 2013 09:14 pm
Turns But Won't Fire GTCRUISER2006 Tech & Performance Forum 2 09 Jul 2012 08:10 pm
Screw turns, but won't come out...? paramo Tech & Performance Forum 6 19 Apr 2011 11:54 am
My PT is OVERHEATING when the A/C turns on...not the fan!! kletson General PT Cruiser Discussions 8 10 Jul 2010 08:25 pm
