Regular or Premium gas?
Like Tree7Likes
Old 16 Aug 2017, 06:57 pm
Question Regular or Premium gas?
Hello ther,
New user here and a very new owner of my 05 PT Cruiser Convertible
I know theres many threads about this..but Im not sure if my Cruiser is a turbo lite or turbo GT
Also, I read that it says on the lid that premium is recommended, but I cant see any of that on my lid....is that common?
Does it mean it is a Turbo lite meaning regular gas would be okay?
Pleas help....New owner and a young student
Old 16 Aug 2017, 07:20 pm
rockandroller's Avatar
Default Re: Regular or Premium gas?
Yer turbolite works with any gas... BUT IT REALLY PREFERS 94 octane
2004 'Turbo Lite'
Old 16 Aug 2017, 07:35 pm
Handy_Cruiser's Avatar
Originally Posted by StudentCruiser View Post
Hello ther,
We've determined that your car is Touring Edition, right? A Touring Edition with the turbo option is a "Turbo Lite". But I've never seen a report that any of these has a decal indicating a preference for premium fuel. But who knows?
Your engine is mechanically identical to the high output GT engine. The only difference is the tuning of the computer (PCM). Your engine is tuned to an advertised 180 hp and can run regular 87 octane or better fuel. That's about the same as an old factory carbureted 350 small block V8 Chevy engine. And it's nothing to sneeze at. The GT is tuned to around 220 hp depending on the year and needs premium fuel to avoid knock. This is due to higher turbo boost pressure and more advanced ignition timing.
My PT vert started life as a Touring Edition. And here's the 8 psi turbo boost with the factory PCM.
And here's the 15 psi boost with the custom Stage 1 PCM from Syked ECM Tuning.
You too can add a Stage 1 PCM to your car and go beyond the GT. You might gain a "theoretical" 50 hp or more though you would need a dyno run before and after to determine the true gains. And you will need to run premium fuel after that.
myckee likes this.
Old 16 Aug 2017, 08:40 pm
Technically speaking you run the highest octane needed to prevent or reduce pre- ignition. (pinging knocking)
If you are in doubt run your VIN to see which model PT Cruiser you have and look up all the specification and run the recommend fuel.
You could always just run the highest octane available in your area but it may not be necessary.
Old 17 Aug 2017, 06:38 am
Question Re: Regular or Premium gas?
I got this when I put my VIN on dodge.com
Any help here?
Vehicle Description 2005 CHRYSLER PT CRUISER 2-DOOR CONVERTIBLE
Monotone Paint
510 Amp Maintenance Free Battery
Power Front Disc/Rear Drum Brakes
Easy Access Passenger Seat
Easy Entry System Seat
Manual Driver Lumbar Adjust
Color Keyed Shift Knob
Rear 50/50 Fold/Tumble Seat
Child Seat Anchor System-LATCH Ready
Next Generation Front Air Bags**
Passenger Compartment Floor Carpet
Cargo Compartment Carpet
Front & Rear Floor Mats
Front Door Sill Scuff Pads
Full Length Floor Console
Non-Locking Underseat Storage Drawer
All 4-Speed Automatic Transmissions
Solar Control Glass
Rear Window Defroster
Cloth Sun Visors w/Illum Mirror
RR View Mirror Read LP/Compass/Temp
Power Mirrors
Keyless Entry,Panic Alarm,2 Transmit
Sentry Key Theft Deterrent System
STANDARD EQUIPMENT
1 08/17/17
Air Conditioning
Deluxe Insulation Group
Route 43 - Benecia, CA
Instrument Panel
Instrument Cluster w/Tach
120 MPH Primary Speedometer
Tachometer
Var Intermittent Windshield Wipers
Single Low Note Horn
12V Rear Auxiliary Power Outlet
Locking Glove Box
12V Front Auxiliary Power Outlet
12V Center Console Power Outlet
Power Decklid Release
Power Auto Central Locking Locks
Power Convertible Top
Pwr Windows, Front 1-Touch Down
ELECTRIC BLUE P/C - Molding - Body
Console Flood Lamp
Front Dome Lamp
Cargo Compartment Lamp
Halogen Quad Headlamps
Fog Lamps
CHMSL Lamp
Backup Lamps
Security Alarm
Front License Plate Bracket
Body Color Eggcrate Design Grille
Rear Body Color Fascia
Rear Sport Bar
Bright Door Handles
PT Cruiser Badge
Chrysler Wing Badge, Hood
Liftgate Chrysler Wing Badge
Touring Edition Badge
EVAP Control System
15 Gallon Fuel Tank
Speed Control
Electric Blue Pearl Coat
AM/FM Compact Disc Radio w/Chgr Ctrl
6 Premium Speakers
Fixed Long Mast Antenna
Power Rack and Pinion Steering
Steering Wheel
Touring Suspension
Front Stabilizer Bar
Tilt Steering Column
Compact Spare Tire
P205/55R16 BSW AS Touring Tires
16X6.0 Aluminum Wheels
-35F Protection Anti-Freeze
Front/Rear Climate Control Outlets
Build To U.S. Mkt. Specifications
GVW/Payload Rating
U.S. 100% GDP Program
Zone 71-Los Angeles
Left Hand Drive (LHD)
Price Class P
3 08/17/17
Two Door Convertible
PT-Vehicle Family
Vehicle Order Tracking
U.S. Specifications Label
California Ship to State Code
Oklahoma Sold to State Code
Cloth Low-Back Bucket Seats
Dark Slate Gray
Smoker's Group
136 Amp Alternator
Multi Position Ash Tray
Lock-Up Torque Converter
2.6 Overall Top Gear Ratio
All Gas Engine
2.4L I4 DOHC 16V Turbo Engine
Color Keyed PRNDL Bezel
Cigar Lighter
2.4L Turbo Badge
Front Body Color Fascia
50 State Emissions
Federal Tier 2, Bin 5 Emissions
Large Diameter Bright Exhaust Tip
Goodyear Brand Tires
Black Cloth Top
Delete Convertible Top Cover Boot
OPTIONAL EQUIPMENT
4 08/17/17
Brake/Park Interlock
Basic Owner's Manual
Manuf Statement of Origin
2 Additional Gallons of Gas
Spring - Left Front
Spring - Left Rear
Spring - Right Front
Spring - Right Rear
FAM: AB TRACKING: 60724T16
FAM: PT TRACKING: 40929S13 MY:2005
Customer Preferred Package 2CF
Customer Preferred Package 2DF
Price Protection - Code Y
2nd Cycle
100% GDP Program
Prepaid Holdback
Sold Vehicle
Fleet Daily Rental W/Client Code
Fleet Option Editor
Fleet Sales Order
Special Scheduling Condition V
Special Scheduling Condition VI
Advance Payment Of SFPAP
DTG Corp.
Paint Order Code
Old 17 Aug 2017, 07:00 am
As Handy said, you can use 87 or better (regular or better) if your car is as it was from the factory. If you upgrade the PCM then you will be required to use only premium.
If it was me, and my car was a Lite and bone stock, I would still run at least mid-grade (89+) just to be safe.
Handy_Cruiser likes this.
Old 23 Aug 2017, 08:06 am
Turbo-Lite, use regular. GT, use premium. NA, use regular. Tuned, use premium.
GT's can use regular in a pinch, but It aint the best idea. I ran regular in my GT at first to highway it, but then used Premium once I got into town.
03' Dream Cruiser Manual: 130k Stage 1, BOV, Koni Shocks, Eibach Springs/Sway Bars, TSW 18x8 Rims, Composite Manifold, 3inch Catless
Downpipe w/Cutout, Magnaflow Catback, Quaife LSD
04' GT Manual Purple PT Mileage: 95k (Died Spring 2018)
05' N/A Automatic Red PT Mileage:121k (Died summer 2017)
Old 23 Aug 2017, 06:04 pm
I ran Murphy regular in my GT 99% of the time. NEVER had any fuel or performance issues. Mostly cooling problems, but since I sold it, I don't have to worry about that anymore!
Old 23 Aug 2017, 06:15 pm
Yeah, but Murphy Oil is an Arkansas based company. That gives their gas at least 6 octane points over all others.
chuzz likes this.
Old 23 Aug 2017, 06:49 pm
I've had my 03 GT for 11 1/2 years, have 137,500 miles on it, Stage 1 for 11 years and I'm sure at least 490 of my approx. 500 fill ups have been the best premium available. Ethanol free when available.
Handy_Cruiser and rob302 like this.
03 Cranberry Base GT A/S debadged.
Make a fast friend, adopt a greyhound.
Is ok to put Regular gas if you been using Premium? ew55 General PT Cruiser Discussions 5 09 Feb 2015 07:34 pm
Premium or Regular gas for 2003 Turbo PT? ew55 General PT Cruiser Discussions 1 29 Nov 2013 07:20 pm
premium vs regular 4SPEED General Turbo Discussions 19 12 May 2011 09:04 pm
Premium gas? Turboguy85 General Turbo Discussions 44 12 Feb 2011 07:31 pm
Regular Gas or Premium blackjersey Turbo Performance 20 30 Mar 2010 04:16 pm
