08 PT Turbo Throwing code
Like Tree5Likes
Old 20 Aug 2017, 10:40 am
Default 08 PT Turbo Throwing code
I have an 08 turbo 89k mi that keeps throwing p2074 code this is what I have done.
sprayed starting fluid looking for vacuum leaks. no surging
Replaced the pressure sensor on the firewall
took the following parts one by one off a good running PT:
MAP
MAF
TPS
I dont have a DRB 111. I am hoping that there is more that I can d Prior to taking it to a dealer. Any suggestions would be greatly appreciated.
Or I would sell it for cheap if you would like t fix it.
Old 20 Aug 2017, 11:02 am
Sinbad's Avatar
Default Re: 08 PT Turbo Throwing code
MAP
MAF
TPS
Have you checked the hoses to the brake servo (booster in Amerikanisch ) and the PCV valve?
I assume the brakes are working OK and the servo is working.
Have you taken off the PCV valve and checked that it rattles when you shake it? (It should)
Have you tried simply disconnecting the battery and leaving off for half an hour, then starting again from scratch?
Old 20 Aug 2017, 11:38 am
P0274 = Manifold Pressure / Throttle Position Correlation; High Flow & Vacuum Leak
Possible Causes:
1. Vacuum leak in hoses or component connections
2. High resistance or resistance to ground in MAP 5 volt supply or signal circuit
3. MAP Sensor has failed
4. High resistance in MAP ground circuit
5. Throttle Position Sensor has failed or is improperly adjusted
6. High resistance or resistance to ground in Throttle Position Sensor 5 volt supply or signal circuit
7. High resistance in Throttle Position Sensor ground circuit
8. PCM has failed
Check all the hoses.
1. Inspect the Intake Manifold for leaks and cracks.
2. Inspect the Power Brake Booster for any vacuum leaks.
3. Inspect the PCV system for proper operation or any vacuum leaks.
4. Check all hoses on the turbo.
If everything above checks out good I would hook up a vacuum gauge and post what you are getting.
CruiserMike and Sinbad like this.
Old 20 Aug 2017, 02:43 pm
Dont have any issues with brakes. PCV is good. I cleaned it for good measure. Throws code still.
I have previously inspected all hoses they all checked out good. I also checked with starter fluid for good measure afterwards as well.
Old 20 Aug 2017, 02:56 pm
Was the timing belt replaced recently?
Old 20 Aug 2017, 03:44 pm
dont think the timing belt has been replaced. Not certain though since I got it from an auction. There are no signs of replacement though.
I am in the middle of ripping the upper end apart again to recheck for cracks and hose leaks.
Old 20 Aug 2017, 05:08 pm
How many miles are on the Pt Cruiser?
Old 20 Aug 2017, 06:58 pm
just over 89k
Old 20 Aug 2017, 08:04 pm
Sinbad's Avatar
89K... from a chop house...
Dr. Sinbads prognosis: original cambelt is like an old rubber band and it's jumped a cog...
But seriously, forget your code and change the cambelt.
Old 20 Aug 2017, 08:21 pm
I would check it out with a vacuum gauge and do all the proper diagnosis first before looking at the timing belt.
JDK52 likes this.
Tags
error code, error codes, p2074, power loss
'05 throwing P0480 & P0481 after AC job...? AcIdBuRn02ZTS General PT Cruiser Discussions 11 22 Jun 2017 08:43 am
PT Throwing Error Codes samxhalo General Turbo Discussions 9 27 Dec 2014 01:28 pm
Timing throwing off the idle? hoggin Tech & Performance Forum 7 31 Aug 2013 10:44 am
I'm throwing some codes sleepy General Turbo Discussions 1 29 Sep 2012 10:14 pm
WE'RE THROWING IN THE TOWEL !! excelawashguy Vendors & Buyers Forum 5 19 Mar 2006 11:43 am
