05 overheating
Like Tree2Likes
Old 26 Aug 2017, 12:42 pm
Default 05 overheating
05 automatic 2.4. New fan, new headgasket, timing belt and tensioner, new temp sending unit, water pump, thermostat, radiator cap is not leaking, new relays, fuses pulled and checked, checked between AC condenser core and radiator and it is not clogged, radiator seems to have good flow. AC blows ice cold at idle and driving, temp gauge sets at half way. Drive 1.5 to 2 miles, AC on or off, and temp starts to rise and you can hear the overflow resivior bubbling over before the gauge gets to the red zone. Pull over and the fan is not working so I check the relays, low speed should be active at this time but power to low voltage circuit for the relay is not there. Waste a few minutes checking things, turn the key and the fan works again, by the time you are almost home it overheats again. Let it idle with the AC running, temp gets to halfway and stays there. Let it idle with AC off, cooling fan cycles as it should and temp drops to below halfway. Everything works like its sposed to till you drive it.
This kinda looks like another thread I have but it is a different vehicle, the other was an overlooked blown fuse. This new vehicle belongs to someone else
Old 26 Aug 2017, 03:14 pm
Default Re: 05 overheating
Leaky head gasket.
Test with kit shown.
Develop relationship with local machine shop.
Enjoy.
Bob in Liberty, MO
Old 26 Aug 2017, 04:05 pm
Sounds like a head gasket leak. Was the head checked before the new head gasket was installed? The tolerance for warping is only .004. One indication and an easy one is to open the radiator fill cap while the engine is running. Often you will see air bubbles as the coolant circulates.
2002 Limited Edition 2.4 Auto with 177k Miles
Old 26 Aug 2017, 10:15 pm
First thing I would do a coolant pressure test. Make sure your coolant system is sealed.
If that is okay check your radiator cap. Make sure its working properly.
Old 26 Aug 2017, 11:15 pm
WrenchnIswhatIdo's Avatar
First thing i would do.?
Manual over ride for the Fan with a switch
Second thing I would Do.?
$18 HF
$11 WM
Originally Posted by Canadian Moose View Post
Just answer one simple question. Do you own any of the following?: Opel, Alfa Romeo, Fiat, Lada, Yugo, Kia, Daewoo, Volvo, SAAB, Jaguar, Land Rover, Chrysler, Dodge, Plymouth, Jeep, Lancia.
If you answered “yes” then parts car is a really good idea.
Old 27 Aug 2017, 01:54 am
I've had good luck with this tester. Lisle 75500 Cooling System - Mechanics Tools
Dan the PT Guy
I'm the world's slowest auto mechanic. I'm typing this signature line instead of working on my car. It always needs something; its a PT Cruiser.
2001 PT Base, 2002 PT Base, 2005 Turbo-Lite Convertible.
Old 28 Aug 2017, 07:48 pm
TurboDucky's Avatar
I had one doing that - Turned out to be a cracked head. I'm guessing that since the head gasket has already been replaced, it's the head itself.
After re-reading the original post, you may want to have the radiator flow checked. Since it's cooling back down at idle, you may have a flow problem. Can't move the coolant fast enough at higher RPM's.
Sinbad likes this.
2005 Dark Slate Gray Convertible - 2.4 Turbo Lite'ish - Automatic.
2001 PT Cruiser - NA - 5 Speed - Exhaust and CAI Mods - It's alive!!!
Old 30 Aug 2017, 01:39 am
The above are good ideas. I have had a very similar trouble with the PT Cruiser.
I also recommend retesting the cooling fan motor just to make sure, because when a cooling fan motor starts to go bad it can work intermittently (as I have seen on the PT Cruiser) due to the commutator in the motor. Re-verify both speeds of the cooling fan and try it multiple times with two individual separate wires direct from the battery. The cooling fan connector (the fan side) has three wires (ground, low speed, and high speed). Find out which wire is which and connect it direct to the battery testing low and high speed.
If none of the other tests find the trouble, I would also make sure that the catalytic converter is not plugged up using a back pressure tester on the port where the O2 sensor is (the engine side of the converter).
Old 30 Aug 2017, 02:34 am
One other question I forgot to ask is does it overheat at high speeds as well as low speeds?
Old 30 Aug 2017, 07:49 am
Fk5 Fk5 is offline
I was going to ask if it ever overheats with the fan on? Car obviously has a fan problem, so why go all in on huge fixes like the head when you can just wire up the fan?
2003 GT 5 speed
162,000 miles
05 overheating cowboyinboxers Tech & Performance Forum 3 31 Jul 2015 08:03 pm
Overheating GrapeApe Tech & Performance Forum 13 01 Sep 2014 11:34 am
Overheating PTmom Tech & Performance Forum 9 15 Sep 2012 04:11 pm
Overheating DreamcruiserII General PT Cruiser Discussions 2 02 Aug 2010 08:39 pm
Overheating Once again!!!! thetinman General PT Cruiser Discussions 4 09 Jul 2010 04:23 pm
