Did I just make a bad deal on my PT Cruiser 05 v
  • 1 Post By rsrocket1
Old 28 Aug 2017, 12:07 am
Default Did I just make a bad deal on my PT Cruiser 05 v
Got my 2005 PT Cruiser Convertible Touring Edition 2.4L Turbo 2 weeks ago
The car has 153k miles on it!
Sad news is..just a week after buying I got check engine light with code P0420 and I feel likle I made a very bad deal...especually with 153k miles(not kilometres) on it..
Also another wide question-
This is the first car I saw where the on the speedometer miles were on the outwide and kilometres were on the inside...unusual for me sicne I lice in Canada
Also the odometer shows miles not kms
Does it mean thecar was made in USA used in USA then imported to Canada?
I posted the specs on my otjer thread from official dodge website and itsaid imported from California!!!
Old 28 Aug 2017, 12:18 am
rckstein's Avatar
Default Re: Did I just make a bad deal on my PT Cruiser 05 v
I guess I would question how practical is it to have a convertible anything in Canada? Would you really get that much use and enjoyment of having the top down?
Old 28 Aug 2017, 01:30 am
Vengence's Avatar
P0420 CHRYSLER - Catalyst System Efficiency Bank 1
Three way catalyst converter Bank 1
O2 Sensors
Exhaust tube
Intake air leaks
Fuel injectors may be faulty
Fuel injector leaks
Spark plugs may be faulty
Improper ignition timing
Engine Control Module (ECM)
May be wiring as well. But, one thing I would do is look under the car where the CAT is and see if there are weld marks. That would signify that they had problems with the CAT before and welded it for a cheap fix and to pass inspection. If that is the case, take it back and have them fix it on their dollar seeing they did work to it. ( had this happen to someone I know)
If that is not the case, then take it to a shop and have them diagnose it. May be a simple fix like a O2 sensor or spark plug, to well.....something bigger as the whole CAT.
Best of luck.
2008 PT Cruiser LX Inferno Red
Old 28 Aug 2017, 11:04 am
Efficiency is a calculated number based on pre cat and post cat readings of O2 sensors. If the O2s are good, then your cat is wack.
03' Dream Cruiser Manual: 130k Stage 1, BOV, Koni Shocks, Eibach Springs/Sway Bars, TSW 18x8 Rims, Composite Manifold, 3inch Catless
Downpipe w/Cutout, Magnaflow Catback, Quaife LSD
04' GT Manual Purple PT Mileage: 95k (Died Spring 2018)
05' N/A Automatic Red PT Mileage:121k (Died summer 2017)
Old 28 Aug 2017, 11:43 am
rsrocket1's Avatar
Get yourself a Carfax report on the VIN and get the history. You can also check the underside of the car. If it's not rotted out and totally rusted, then it probably did spend much of its life in California. All the cars I've owned spent all their lives in California and rust underneath the car is one of the things I've never worried about.
US cars do have their speedometer readouts in MPH on the outside and kph on the inside.
rockandroller likes this.
PT Cruiser on CraigsList.. is it a deal?? PTLUZER General PT Cruiser Discussions 16 04 Mar 2017 01:52 am
Good deal on a DIY PT Cruiser kit $550 in Alabama Moparman440 craigslist 0 11 Oct 2016 10:54 am
In the market for a PT Cruiser wondering if this is a good deal. SirCorbit Tech & Performance Forum 9 06 Aug 2013 07:58 am
2002 PT Cruiser $3,200...Good Deal? SmashCarRacing General PT Cruiser Discussions 5 11 Mar 2009 07:30 am
Did I make the right deal? 2005 GT Conv tpsfoto PT Cruiser Convertible Forum 17 09 Nov 2007 12:04 am
