trim removal
Like Tree9Likes
Old 29 Aug 2017, 12:29 pm
Default trim removal
Not sure how to remove the trim piece(s) below the steering wheel on my 08 PT. IIRC the correct name for this is the "knee bolster". Anyway, there appears to be no fasteners holding it on. How is it removed (without destroying anything)?
Old 29 Aug 2017, 12:47 pm
rckstein's Avatar
Default Re: trim removal
It's been a while since I've done it, but I believe you have to remove the trim pieces on both sides of it then that will expose some fasteners that need to be removed. Be careful working in that area as there is an airbag behind that cover!
Old 29 Aug 2017, 01:23 pm
Sinbad's Avatar
Er, don't know about yours, but my 07 diesel has an airbag down there, so go careful or you might get a nasty surprise
rckstein likes this.
Old 29 Aug 2017, 01:24 pm
rckstein's Avatar
I put that warning in my post, but I just highlighted it, would hate to see something happen to someone.
Sinbad likes this.
Old 29 Aug 2017, 01:48 pm
sanatanadharma's Avatar
Disconnect the battery!!!!
Start with the panel below the steering column. "Use a trim stick to release the catch tabs (that are on the) on the backside of the panel. The top is held on by clips. Remove the panel"*
Essentially, you pull the snap clips out from the dash at the top edge.
Tight but the clips do pull free.
You will now see screws and all ought be intuitive.
*Quoted, with my edit, from the PT-specific Mopar EVS-1 security alarm system installation manual from my DIY alarm installation; like factory (it is Mopar), but with the instruction manual, and disable and alarm-off abilities.
rckstein, ptprice and Sinbad like this.
Old 29 Aug 2017, 02:29 pm
OK, thanks for the replies... not going to mess with it since it in involves an air bag.
Will find an alternate location for my project.
Old 29 Aug 2017, 02:32 pm
Originally Posted by rckstein View Post
Please let me know when you've downloaded the manuals as I'm going to delete the links, thanks.
Won't be needing.
Thanks.
Semper Fi.
Old 29 Aug 2017, 02:38 pm
another reason the earlier models are a smidge better to work on, that panel is just removed by prying at the top between it and the column. pops right off and swings down. Although.... an extra airbag couldn't hurt.
03' Dream Cruiser Manual: 130k Stage 1, BOV, Koni Shocks, Eibach Springs/Sway Bars, TSW 18x8 Rims, Composite Manifold, 3inch Catless
Downpipe w/Cutout, Magnaflow Catback, Quaife LSD
04' GT Manual Purple PT Mileage: 95k (Died Spring 2018)
05' N/A Automatic Red PT Mileage:121k (Died summer 2017)
Old 29 Aug 2017, 02:40 pm
rckstein's Avatar
The Gen1 doesn't have an air bag under there?
Old 29 Aug 2017, 02:46 pm
nope. One of the few revisions of the interior on the Gen2s. The crash tests showed that knees didn't come out as safe as they wanted them too in frontal crashes. tend to crumple and stuff themselves under the bolster, so an airbag "helped" with that.
Seat trim removal help 06OregonCruiser General PT Cruiser Discussions 3 29 Jul 2015 11:38 am
Interior Hatchback Trim Removal mdfrodolives General PT Cruiser Discussions 8 22 Aug 2011 03:21 pm
Trim Removal on Convertible mopar1cjh PT Cruiser Convertible Forum 0 17 Dec 2010 07:10 am
Liftgate (rear) Trim Panel Removal Limprod Interior Accessories Forum 3 11 Oct 2010 05:19 pm
Self Adhisive Trim Removal LCH Exterior Accessories Forum 9 09 May 2009 11:48 am
