2002 pt cruiser breaking up when i hit the gas
Old 30 Aug 2017, 11:37 am
Default 2002 pt cruiser breaking up when i hit the gas
My pt cruiser is vreaking up when ihit the gas in park andand in drive....doesnt do it in reverse...im getting codes
P0122
P0123
P1496
Anyone have suggestions how to fix this....already switched the PCM the map sensor and TPS.
Ive wiggled wires while its running idle never changes...any ideas or suggestions will be appreciated.
Old 30 Aug 2017, 11:56 am
VsandFords's Avatar
Default Re: 2002 pt cruiser breaking up when i hit the gas
Welcome to the forum from Texas. Please go to the new members section and tell us about yourself and your Cruiser.
Have you gone to the internet and google/bing the codes? What I saw was TPS and low voltage.
Old 30 Aug 2017, 01:35 pm
rob302's Avatar
should not have a 122 and a 123 unless you unplugged the TPS while running. suggest you clear the codes and report which come back. otherwise you'll be getting all kinds of odd advice on here
Old 30 Aug 2017, 02:19 pm
Originally i was getting low voltage codes...now i think its down to the tps car breaks up around 3k rpm...with live data running it says tps is doing nothing when i hit the gas....i took tps off tried rotating a little before then bolting it on then scanner read 99.6% use....why wont the tps catch the flap....its like it isnt sitting in the right spot so it will get a readding when the throttle body butterfly starts rotating does that mean its shot?
Old 30 Aug 2017, 06:55 pm
I would suggest checking the wire harness from the camshaft sensor to the PCM. It is very common problem that the wire harness drops down on the half shaft or chassis and start shorting out wires on the 2001 & 2002 Pt Cruisers. It might be affecting the battery voltage.
Old 30 Aug 2017, 07:35 pm
Originally Posted by ptcruisersteve View Post
I would suggest checking the wire harness from the crankshaft sensor to the PCM. It is very common problem that the wire harness drops down on the half shaft or chassis and start shorting out wires on the 2001 & 2002 Pt Cruisers. It might be affecting the battery voltage.
Steve, that's the CAMSHAFT wiring harness that drops down and hits the halfshaft. Did it to mine.
Old 31 Aug 2017, 09:41 am
rob302's Avatar
Old 31 Aug 2017, 09:43 am
rob302's Avatar
Old 31 Aug 2017, 09:47 am
rob302's Avatar
easier since you have a scanner... When you take the sensor off the throttle body, connect the wires to it, turn the key to the run position (without starting).. does the sensor value read correctly as you rotate the middle part?
99.6 is obviously wrong. if it reads 0-20% at idle. that would be normal the car tares whatever percent to 0 like a digital scale
Old 31 Aug 2017, 11:54 am
Thanks for replys....i put brand new sensor on now its functioning...at idle says tp% is 16% i put in drive hit gas it breaks up and shoots code p0122. In reverse does break up i can hit rev limiter no problem in park it breaks up if i rev
And in neutral....so look at harness in what general area?
Im gonna throw on lift now
PT Cruiser breaking down under load at light. Quadcab06 General PT Cruiser Discussions 9 26 Aug 2017 10:33 pm
Breaking up a cruiser.. best parts to keep as spares? Lankytim General PT Cruiser Discussions 2 26 Aug 2016 07:28 pm
UK Based 2002 Ltd Edition Gold - Breaking for parts breakingPT Classifieds: For Sale/Trade 1 16 Apr 2014 06:29 am
AIR BOX TABS BREAKING littleblueGT Turbo Performance 4 23 May 2005 06:45 pm
