PT 2006 Alternator Connector
Like Tree3Likes
Old 30 Aug 2017, 12:27 pm
Default PT 2006 Alternator Connector
Anyone know how to disconnect the wiring from the alternator on a 2006 PT?
With light to medium force, every which way I try the connector won't release.
Any help on this would be great.
I do not want to break the connector.
Thanks for any input
Old 30 Aug 2017, 12:58 pm
Default Re: PT 2006 Alternator Connector
That red part slides back a bit then you can push the rear of the plug and release the lock
Handy_Cruiser likes this.
Old 30 Aug 2017, 01:03 pm
Thanks for the fast reply!
I can't get the red part to move at all.
Should I push the red part towards the alternator or away from it?
Old 30 Aug 2017, 04:12 pm
Pull on the red clip. You can always try slipping a small flat blade screwdriver in there to CAREFULLY pry it in that direction. They break pretty easily, so be patient.
Old 30 Aug 2017, 05:48 pm
RickinPA's Avatar
I've used a standard stubby flat blade screwdriver on those locks with success. As stated before "CAREFULLY". I'd give it a little nudge, and if it moves, you nudge it some more. If it doesn't move, STOP and evaluate. I suspect the red locking tab goes away from the connector. That usually frees a plastic piece to lever when pressed down to unlock the connector.
Old 30 Aug 2017, 08:22 pm
Thanks to all for the replies.
I did try getting in there with a flat blade but all I manged to do was cut into the red plastic a bit.
There really is not much room to maneuver.
I had to take it off the ramps and park it for the night but I will be getting back to it soon.
Thanks again.
Old 30 Aug 2017, 08:30 pm
rckstein's Avatar
Thanks again.
Someone please correct me if I'm wrong, but doesn't the red tab need to be slid to the left (in the direction of the yellow arrow) towards the wires, to be able to unlock the connector?
Old 31 Aug 2017, 10:36 am
yes
'03 GT base w/175k and a 2 speed autostick (read: trans is shot) and powered by a hybrid MOPAR S3 with DSP untuned
1st Forward Motion E1 powered PTGT w/Psi-Fi Power pack fuel tuner back in '07
FS: '03 GT Elec Blue w/rear suicide doors or '03 auto PCM, S3 turbofold, WGA, 3.5" o2 & 3" DP - make offer
Old 31 Aug 2017, 11:41 am
Yes that is my thinking exactly.
However I cannot get it to budge.
My flat blade screw driver just slips off of it and leaves a little mark in the tab.
I have applied a fair amount of force as well.
Clips like this are meant to be taken off so there is something I am missing because it should not take a tremendous amount of force.
Thanks again for all the help and the graphics too!
Much appreciated.
Old 31 Aug 2017, 12:11 pm
VsandFords's Avatar
When I have a stuck tab, as I am applying some force I also try to wiggle it from side to side to help loosen it. Sometimes with good results. Sometimes when it comes loose, it breaks anyway. Just to spite me, I'm sure!
2006 2.4 Turbo Battery/Alternator Issue brandontbf Tech & Performance Forum 10 14 Sep 2015 09:53 pm
I need a connector Chrisd069 Classifieds: Want To Buy 25 27 May 2012 10:23 pm
Alternator Voltage PT 2006 bob2006 Tech & Performance Forum 7 11 Mar 2011 10:28 pm
Where to find a hi output alternator for a 2006 non-turbo?? Samson Tech & Performance Forum 0 27 Dec 2009 12:10 am
What's the connector pinout for 2006 alt? mluckey General PT Cruiser Discussions 2 27 Aug 2008 07:28 pm
