Throwing Codes
Old 31 Aug 2017, 08:46 am
Default Throwing Codes
I have a 2003 PT GT. I checked the codes last night and looks like it is throwing a few: P1188, P0420, and P0441. I checked the codes because I can hear almost a whistling when I accelerate. I looked up the codes and am going to change the plugs as they need to be done anyway. Looks like maybe a loose vacuum hose related to the turbo. Any thoughts?
Old 31 Aug 2017, 08:55 am
rob302's Avatar
Default Re: Throwing Codes
nevermind.. crack in exhaust manifold maybe?
Old 31 Aug 2017, 09:20 am
P1188 TIP Sensor Performance
Non-boost Mode: PCM detects a significant difference between TIP Sensor signal and BARO Pressure signal.
Boost Mode: The TIP Sensor is unable to read correct boost level.
Possible causes include:
Hoses and Tubing
Vacuum Supply to Surge Solenoid
Solenoid Test
Turbocharger
Wastegate Actuator
Check all of the tubes and hoses between the air cleaner and the intake manifold for loose connection, damage or restriction.
Check all of the tubes connected to the intercooler for loose connection, damage or restriction.
Check all of the tubes and hoses connected to the turbocharger, TIP Solenoid, Surge Solenoid and Wastegate Solenoid for loose connection, damage or restriction.
Pt cruiser throwing 10 codes dailyboostin Tech & Performance Forum 10 04 May 2016 07:04 am
throwing codes 0121 & 0129 cannesman Tech & Performance Forum 3 05 Apr 2015 04:05 pm
PT Throwing Error Codes samxhalo General Turbo Discussions 9 27 Dec 2014 01:28 pm
Help with '01 NO spark/Start/throwing codes.. PLEASE!! domsob1974 Tech & Performance Forum 22 02 Sep 2014 09:26 am
I'm throwing some codes sleepy General Turbo Discussions 1 29 Sep 2012 10:14 pm
