07 turn signal problem
Old 02 Sep 2017, 10:19 pm
Default 07 turn signal problem
Hey y'all. I have a left rear turn signal not working.
I changed the bulb and socket. Left front flashing like the rear bulb is out.
When I pulled the bulb, it was a dual filament bulb. Is this the correct bulb?
Would figure it to be a single since it only operates as a turn signal.
Old 02 Sep 2017, 10:43 pm
rckstein's Avatar
Default Re: 07 turn signal problem
The correct bulb for the rear turn signals is 3757A.
Old 03 Sep 2017, 06:09 am
Check the wiring for a loose or broken ground wire.
2006 TURN SIGNAL PROBLEM dj78nc General PT Cruiser Discussions 26 24 May 2015 12:52 pm
Turn Signal Problem Larry2828 General PT Cruiser Discussions 8 12 Nov 2014 01:04 am
Turn signal problem Karenscruiser Tech & Performance Forum 2 12 Jun 2012 02:12 am
Rear turn signal problem leroy420 General PT Cruiser Discussions 5 18 Feb 2009 09:43 pm
Turn Signal Fuse Problem Indynick General PT Cruiser Discussions 1 04 Jul 2004 07:33 pm
