How much clutch fluid?
Like Tree2Likes
  • 1 Post By rob302
  • 1 Post By Govert
Old 04 Sep 2017, 07:14 am
Govert's Avatar
Default How much clutch fluid?
Hi,
Does anyone know how much fluid is in the hydraulic clutch system.
Thanks for helping
Old 04 Sep 2017, 07:34 am
rob302's Avatar
Default Re: How much clutch fluid?
"not much" maybe .75 pint?..all the shop computer says under fluid specs is "dot 3 brake fluid.
Nobody knows what that part is in your other thread because it not something they sell. It's just something on the slave line. I'd guess you could live without it. I don't think later year PT's have it.
Clutch hydraulic questions here seldom get correct answers. Nobody here could tell me how to correctly bleed mine. I got advice but found mine had no bleeder. Looking it up there are so many different versions of the hydraulic junk it made me wish it was a cable clutch.
This is one area that lacks knowledge on here.
For my PT all I could do was order a master/slave pre-bled kit for $200 so I lived with the leaky junk
Govert likes this.
Old 04 Sep 2017, 08:06 am
Govert's Avatar
I've googled around and found that the part in the slave line should be a "damper" (other car brands have a similar part) Without it would make the clutch better (stiffer) say many,I give it a try.
Thanks for helping!
Old 04 Sep 2017, 08:23 am
rckstein's Avatar
Here's from the '01 Parts Catalog:
Here's from the '03 Parts Catalog where they no longer use that part:
Old 04 Sep 2017, 09:53 am
Govert's Avatar
Yes, exactly what i meant, thanks!
rckstein likes this.
Clutch Pedal / Clutch rvj2184 Tech & Performance Forum 4 07 Jun 2017 02:28 pm
Clutch and Brake fluid :confused: barryfromwales Europe PT Forum 2 29 Jan 2017 12:34 pm
Picture of clutch fluid reservoir cap ? rasec8711 General PT Cruiser Discussions 19 30 Dec 2013 09:35 am
01 Clutch oddity-possible clutch master cylinder? opelenvy Tech & Performance Forum 6 17 Sep 2008 03:35 pm
GT 5 speed clutch noise or " clutch chatter". boosta General Turbo Discussions 3 11 Aug 2003 08:10 pm
