2005 ignition housing removal
Like Tree3Likes
  • 1 Post By rckstein
  • 1 Post By vinnie
  • 1 Post By rob302
Old 04 Sep 2017, 06:06 pm
Default 2005 ignition housing removal
Does anyone know how to remove the cast housing for the ignition cylinder from the actual steering column? It seems to wiggle but not come off. Have the column stripped of anything that is in the way, including the steering wheel and all the ignition parts, except the cast housing. This is a parts car Im stripping down.
Thanks, Vince
Old 04 Sep 2017, 06:24 pm
rckstein's Avatar
Default Re: 2005 ignition housing removal
Do you have a copy of the Service Manual?
bob2006 likes this.
Old 04 Sep 2017, 07:26 pm
Thanks. Downloaded it.
Looked thru the whole section. It shows how to do everything except remove the cast ignition housing that is attached to the steering wheel end of the steering column.
Anyone else ever try to do this? Maybe I have to take out the whole column, and that is replaced with the cast housing.
rckstein likes this.
Old 05 Sep 2017, 01:52 pm
rob302's Avatar
are you implying you're trying to remove the cast aluminum part shown here off the steel tube?
you've removed the steel brace and the two bolts marked with red arrows?
i'm curious as to WHY you'd bother if only stripping down a parts car
Handy_Cruiser likes this.
Old 05 Sep 2017, 01:56 pm
Yes. Just thought Id strip down every part.
Old 05 Sep 2017, 01:59 pm
rob302's Avatar
i edited that. if the two bolts i marked with arrows are out, i'd try a small hammer.
2006 and up Ignition redesign- Key cylinder removal JoeX General PT Cruiser Discussions 18 08 Dec 2016 03:35 pm
GT thermostat housing removal gmrviper General Turbo Discussions 17 12 Sep 2016 01:50 pm
Need 5 star torx for key cyl. housing removal JcHoge11 General PT Cruiser Discussions 5 05 Sep 2016 06:49 pm
2005 ignition switch nicky1 Tech & Performance Forum 4 25 Aug 2014 05:09 pm
:( Broken ignition housing 2005 turbo convertible. Deen General PT Cruiser Discussions 0 16 Aug 2010 03:10 pm
