Alternator / battery light
Old 06 Sep 2017, 09:22 pm
Default Alternator / battery light
On my 2007 model, the battery light comes on after driving 5-6 minutes with only a/c and fan on. It doesn't drain the battery and will continue to run fine indefinitely this way. If you turn the engine off and restart, the light does not come on until 5 minutes again. I have a battery alternator tester plugged into the power port and the battery and alternator voltage remain normal before and after the light comes on. I checked the codes and it is not throwing any codes. The battery is new. The battery connections have been cleaned and are secure. 106k miles 2.4. Anyone run into this before or know what might be happening?
2008 PT Cruiser - Battery Light - Alternator, Timing Belt? JJenn74us General PT Cruiser Discussions 6 01 Sep 2015 11:16 am
Need some advice on battery alternator krazykanuk Tech & Performance Forum 32 03 Nov 2014 08:18 pm
Battery / alternator Rascal Tech & Performance Forum 28 07 Sep 2013 04:24 pm
Battery or Alternator? Busa_Powered General PT Cruiser Discussions 8 21 Oct 2011 11:29 pm
Pis**ed Off Battery / Alternator tommyis3 Tech & Performance Forum 11 28 Aug 2010 01:20 pm
