2005 PT Vert N/A 5-spd possible tranny issue
Like Tree4Likes
Old 09 Sep 2017, 07:59 pm
Dill's Avatar
Default 2005 PT Vert N/A 5-spd possible tranny issue
Howdy everyone.
My 2005 PT convertible with a 5 Speed manual transmission has not been running right lately.
Recently I replaced the following parts:
Oil sending unit
Valve cover gasket
Spark plugs
PCV valve
When I put the car in gear to go the car seems to really bog down. It goes into gear fine (booger bushings) and doesn't kick out. It just takes more rpms to get move movement than I am use to. I can also press the gas pedal down and the rpms goes up but no real change in momentum. Once I'm on a highway everything seems fine. No weird noises or anything.
I took it to a service station and they say it is the clutch pressure plate, clutch disc and clutch release bearing. I just can't believe this would happen just a few weeks after all the other work I did to stop oil leaks.
Does this seem about right?
Old 09 Sep 2017, 08:11 pm
VsandFords's Avatar
Default Re: 2005 PT Vert N/A 5-spd possible tranny issue
Hey, Dill!
Hate to say it, sounds like your clutch is worn out. The work you did recently would not have any affect on clutch wearing out. Has it been replaced before? How many miles on it?
Handy_Cruiser and Carnut like this.
Old 09 Sep 2017, 08:23 pm
Welcome back Dill,
It's been a long time since I have worked on a clutch but other members like Rob302 would be able to give you some good advice.
Is the engine light on? If so what are the engine trouble codes and if it has any transmission codes? If it has P0700 code I would suggest taking it to a transmission repair shop that offers for free to tell you what transmission codes have been triggered if any.
Post what additional information you can give us and welcome back again.
Old 09 Sep 2017, 09:19 pm
Dill's Avatar
Hello,
PT has 180k on it. Timing belt recently changed so was hoping for another 100k on it.
Check engine light has come on and gone off. Read codes but nothing shows up. I do not believe the clutch has been replaced before. I've never had a clutch go in all my manuals I've ever owned. I thought it was a gradual issue coming from improper technique. This was so sudden out of nowhere that it really confused me as to what could have gone wrong. I'm being quoted $1200 to repair. Also needs a new evaporator as the A/C doesn't work anymore. That's another $1k.
Old 09 Sep 2017, 09:37 pm
I would suggest taking it to a transmission shop that will check for codes for free if you have one nearby.
Old 10 Sep 2017, 06:39 am
VsandFords's Avatar
The clutch disc is made of a friction material, like brake pads. Eventually it will get glazed and hard or wear thin enough to stop grabbing. The cost of repair on it and the A/C is still a lot less than buying a different vehicle. Especially if you have not needed to spend any on it for a while.
Old 10 Sep 2017, 12:45 pm
rob302's Avatar
If you need a clutch, I used the $140 clutch kit of Rock Auto and beat the hell out of it with no regrets. Would take about 4 hours to complete. Not a fun job, but much easier than a timing belt
3rcruiser likes this.
Old 10 Sep 2017, 01:44 pm
MJKnight's Avatar
My 01 clutch lasted to about 150,000 miles
Then gave out ...all at once...gone
Old 12 Sep 2017, 11:28 am
Dill's Avatar
Which one of these kits would have everything I would need?
https://www.rockauto.com/en/catalog/...lutch+kit,1993
Car won't move out of the driveway now. Shifts into gear but letting off clutch does nothing, car doesn't even stall and idle doesn't change.
Old 12 Sep 2017, 11:43 am
Fk5 Fk5 is offline
I don't think the manual will throw any codes. It is just a simple 5 speed. Shouldn't be much electronic to throw a code. I have had my flywheel completely delaminate and separate without so much as a peep from the codes/check engine light.
2003 GT 5 speed
162,000 miles
2005 Turbo GT 'vert hismiths Turbo Wheels/Suspension/Handling 1 15 Dec 2016 09:02 pm
'05 GT Vert starting issue... Rayvin60 Tech & Performance Forum 4 13 Dec 2016 03:16 pm
2005 Gt vert. - new to me! - some questions domer94 PT Cruiser Convertible Forum 5 23 Aug 2016 03:34 pm
2006 Auto Tranny Issue! Please Help!! PTnorm Tech & Performance Forum 30 24 Dec 2011 09:09 pm
LTB 2005 GT Vert gawe22 Classifieds: Want To Buy 0 09 Feb 2011 05:06 pm
