Oil ligjht came on under hard braking. Normal?
Like Tree24Likes
Old 13 Sep 2017, 05:45 pm
Gkon's Avatar
Default Oil ligjht came on under hard braking. Normal?
Hi guys and gals,
Yesterday, as I was driving home from work, I had to slam on my brakes to come to a sudden stop. I was just short of skidding.
When I did that, my oil light came on for a couple of seconds and then turned off.
I mimicked the same situation and had the same result.
After I got home I checked my oil level. The oil was hot and the level was just shy of being right between the two dots on the dipstick in the area for checking hot oil, as it should be.
What gives? Is this normal? Should I add a little bit of oil? I don't want to overfill it.
I remember on my old Kawasaki kz900 there were oil starvation issues under extreme braking conditions. Does the PT have similar issues?
Thanks.
2002 PT Cruiser Limited, 2.4L, Automatic Transmission, Metallic Silver Paint
Old 13 Sep 2017, 06:11 pm
Handy_Cruiser's Avatar
Default Re: Oil ligjht came on under hard braking. Normal?
I believe that the first thing to do when this type of symptom comes up is simply to change the oil with the correct high quality stuff and with a good quality filter.
This will eliminate several of the more common and easily rectifiable causes such as burnt oil, wrong oil, cheap oil, stopped up filter, low oil, etc. And then you can see if the issue returns. And if it does, it might indicated a more serious problem.
Old 13 Sep 2017, 08:15 pm
Gkon's Avatar
My oil and filter were changes by my reputable mechanic who used quality oil and filter and I'm not yet due for an oil change.
Also, I baby my car and drive it like an old man.
I don't know that you actually answered my question, though.
Old 13 Sep 2017, 08:33 pm
VsandFords's Avatar
Gkon, I can't tell you it is common on a Cruiser, however, anytime you hammer the brakes and the RPMs go from 2-3 grand to nothing in a flash, the light could come on. The lower the RPMs, the lower the oil pressure. Since you haven't had this issue during your day to day travels, I wouldn't be concerned.
Just my opinion.
NitroPT and Gkon like this.
Old 13 Sep 2017, 09:42 pm
WrenchnIswhatIdo's Avatar
If it was Me First thing Pull the dip stick smell the oil
make sure you can.t smell fuel in the oil
Possibly you qualified mechanic put the "Non proper weight or Multi weight"
oil in your cars engine
In any case........ Even if your oil was Just changed
This is a red Flag
an a sign to change the oil again
and look what in the oil after change Hopefully it just the oil
if you see Goldsilver flakes in the oil...
........Houston we have a Problem.!
Handy_Cruiser and Gkon like this.
Originally Posted by Canadian Moose View Post
Just answer one simple question. Do you own any of the following?: Opel, Alfa Romeo, Fiat, Lada, Yugo, Kia, Daewoo, Volvo, SAAB, Jaguar, Land Rover, Chrysler, Dodge, Plymouth, Jeep, Lancia.
If you answered “yes” then parts car is a really good idea.
Old 14 Sep 2017, 11:07 am
Gkon's Avatar
Thanks to everyone for their input.
My oil wasn't just changed, but it is still within the recommended driving range. However, a fresh oil change and filter sound like cheap insurance and may show if there is another underlying problem.
Again, this only happened under severe braking, going from 35mph to 0mph as fast as one can without actually skidding. It seemed like the oil sensor was starved for oil for a second or two because of the sudden stop and inertia.
That's why I suspected possible low oil level, which it didn't seem to be.
My oil light has never come on with normal driving and braking.
I'll check for gas smell in the oil in a bit.
Like I said, this reminded me of my old kz900. They have a low pressure/high volume system so, under severe braking, the oil pump would be starved for oil because it woul all end up on the other side of the oil pan for a second.
Most guys that drag raced would weld a deeper portion onto the pan, as I've seen some of you all do to your PT's. That's why I thought it might be a common issue.
Old 14 Sep 2017, 11:08 am
PM sent
Gkon likes this.
Old 14 Sep 2017, 11:14 am
Fk5 Fk5 is offline
Just had the oil light scare, so I have read a bit about this one. Mine turned out to be the oil pressure sender/switch. $15 fix. These cars apparently have pretty low oil pressure at idle. Dropping the rpms a tiny bit can make it drop even further causing the light to come on. I am not really a fan of "repeating" a low oil pressure problem, but next time you do, check your revs. If you are under 700, I don't find it surprising. The car is basically stalling - then you can check your IAC and stuff that sets the idle and maybe see if it is a vacuum thing from the power brakes.
2003 GT 5 speed
162,000 miles
Old 14 Sep 2017, 12:09 pm
Gkon's Avatar
Originally Posted by NitroPT View Post
PM sent
Thanks. I'll check it out.
Thanks for the info. I'll check to make sure, but I'm pretty certain the Rams dropped and quickly because of the severe braking. As mentioned, it was braking as hard as you can and combing to as abrupt Of a stop as you can just short of skidding.
Just smelled the (cold) oil. Not a whiff of gas smell, and the level is where it should be.
Old 14 Sep 2017, 12:13 pm
cruserdad1976's Avatar
Im sure Nitro told you to send the oil to the lab and have it testes which is a great idea?
the oil sending unit was mentioned that too is a great idea to have it changed
I guess if you were really concerned you could put a manual oil pressure gauge on the PT
I really have no idea what the oil pressure runs on a PT
changing the oil is never ever a bad idea
if you do all this all it all looks good id say you are safe
Pt Braking Issue. Snowmanner Wheels, Tires, Suspension 3 29 Nov 2016 07:39 pm
HELP!!! ...Braking... TangerineDream76 General PT Cruiser Discussions 13 14 Dec 2014 10:35 pm
Transmission slips intermittently after hard braking Slowrider Tech & Performance Forum 9 07 Aug 2013 10:26 pm
Wet Braking Problem compdr59 Tech & Performance Forum 7 18 Feb 2012 11:59 am
Braking problem ??!! junkno General PT Cruiser Discussions 10 13 Aug 2004 07:10 pm
