Red Airbag Light On After Wheel Alignment
Like Tree2Likes
  • 1 Post By wb2kki
  • 1 Post By wb2kki
Old 14 Sep 2017, 05:33 am
Default Red Airbag Light On After Wheel Alignment
Hey folks,
I just had new struts installed on my 2008 PT Cruiser, along with two new tires and an alignment. Then one day later, my red airbag light started coming on & off every 5-10 minutes.
2 days later, the red airbag light remains on almost all the time, and I now noticed that when I'm at a stop sign and make a hard 90 degree right turn, the red airbag light will always turn off, but then come back on after driving straight.
I found one post (https://answers.yahoo.com/question/i...9115655AA8viCW) that eluded the clock spring must be re-centered if the front wheels were removed.
Is this just one of those odd coincidences where I get my car back and the clock spring happens to break, or did the mechanic forget to re-center the clock spring after new tires and alignment.
Ya'lls feedback is always appreciated!
Frank
162,000+ miles from original struts (although they drove like it)!
Old 15 Sep 2017, 09:56 am
Default Re: Red Airbag Light On After Wheel Alignment
Wheel alignment should not hurt the clock spring unless it was about to. You need to check the wire to the collision sensors. Other than that you will need a scanner to determine the the fault. Most DYI scanners don't have that option so you can go to auto zone or such and have the read the codes may send you in the right direction. If this is a shop you go to all the time bring it back have them check it.
ptprice likes this.
Old 15 Sep 2017, 09:57 am
PS!!!!! WARNING!!! do not play with the wires with the battery connected. You don't want to set off the air bag. Bad thing!!
ptprice likes this.
Old 15 Sep 2017, 10:06 am
Thanks for your reply. I read up plenty about airbag and the need to remove negative battery terminal and wait 5 minutes, but I'm not going to mess around with it. I had Tread Quarters do the original strut and wheel install and alignment.
I have to have new front wheel bearings and hubs installed, so I'll have TQ take a look at it.
Thanks again!
Old 16 Sep 2017, 07:46 am
By way, sure it is air bag and not ABS
Tags
clock spring, clockspring, wheel alignment, wheels removed
2006 pt cruiser airbag light and seatbelt light Benjamin9669 Tech & Performance Forum 1 15 Mar 2017 03:02 pm
Wheel alignment SAI PeteyGT Turbo Wheels/Suspension/Handling 11 14 Apr 2013 10:05 am
car wont start. car alarm light and airbag light on trigimon Tech & Performance Forum 7 05 Nov 2010 03:42 pm
Wheel Alignment Specs UnionJak Wheels, Tires, Suspension 0 16 Oct 2010 01:24 pm
wheel alignment onyx pt Turbo Wheels/Suspension/Handling 2 19 Aug 2005 09:10 pm
